Old 07-29-2011, 04:23 PM   #1
BENC-10
Exclamation Towing????
Howdy everyone, I just purchased a 1970 swb c10 and i was wondering if i can use a U-HAUL TRAILER, to haul back home. Any help is greatly appreciated
BENC-10 is offline   Reply With Quote
Old 07-29-2011, 04:25 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Towing????
As long as it has stock tires it should work, I used them a couple of times to move mine.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-29-2011, 04:31 PM   #3
BENC-10
Re: Towing????
AWESOME!!, and how is the fit? do the rear tires hang over?
Old 07-29-2011, 04:56 PM   #4
cdowns
cdowns's Avatar
Re: Towing????
dont tell uhaul that you will b towing a pickup truck on the trailer//they wont rent to you
the biggest uhaul trailer everything fits but it is close fit
Old 07-29-2011, 05:59 PM   #5
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Towing????
Heard u cant go over 55 mph with them. They sway above t5hat so if u have a long drive rent a real trailer
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 07-29-2011, 06:04 PM   #6
blkcorvair
blkcorvair's Avatar
Re: Towing????
Towed my 69 Shortbed C10 Home on a full Uhaul car hauler. Fit perfect and it worked great. I told em that was the truck I was picking up and they said it works fine according to thier system as well. I was doing 65+/- with it with no problems. Honestly I think some of there trailers are better than the backyard car trailer builders I have seen. I did tie it down with some of my own extra straps too.
blkcorvair is offline   Reply With Quote
Old 07-30-2011, 12:10 AM   #7
BENC-10
Re: Towing????
SWEET!! THANKS GUYS. I knew I came to the right place
Old 07-30-2011, 12:17 AM   #8
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: Towing????
Welcome from Texas! yep this is the right place, you will come to depend on the guys here for a lot of information, I know I have
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 07-30-2011, 08:58 AM   #9
Vintage Windmills
Vintage 4x4s
Re: Towing????
i wonder if they said it would fit because it was a swb. So many guys have said it wouldn't fit according to U haul but maybe they had lwb trucks. Also, the swaying will be worse with a lwb since you have more weight to the rear of the trailer.
Yes, this site is a good one.
Old 07-30-2011, 10:45 AM   #10
eurospec1
eurospec1's Avatar
Re: Towing????
I work for Uhaul corporate, we have updated alot of our systems for vehicle sizes over the past year, and i can confirm that every 67-72 chevy truck made up to a 4x4 c20 longbed will fit our trailer. Now, alot of times a towing combo is turned down not because of the truck going on the trailer, but due to the weight and towing capacity of the vehicle pulling it.
As for swaying, sway is caused by not enough tongue weight, if you get swaying with one of our car haulers, and the car is on the trailer correctly (not backed onto the trailer) then your ball is most likely to far off the ground, and you need a drawbar with more drop on it, to get the nose of the trailer correctly angled down.
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 07-30-2011, 11:13 AM   #11
BENC-10
Re: Towing????
Thanks for the info Eurospec, hopefully picking the truck up today...
One more question do you think I will be able to tow it with my 03' Tundra??
Old 07-30-2011, 11:19 AM   #12
eurospec1
eurospec1's Avatar
Re: Towing????
Get me the info on the tundra and i will check, ie:
reg extra or 4 door cab
2wd or 4wd
towing capacity of the trailer hitch that's on it
68 SWB Fleet 383
Old 07-30-2011, 11:40 AM   #13
BENC-10
Re: Towing????
its a standard cab, 2wd, v8...towing capacity says its about 5000lbs
Old 07-30-2011, 12:20 PM   #14
eurospec1
eurospec1's Avatar
Re: Towing????
Would need a bigger tow vehicle, combined weight of the c10 + our trailer would exceed 5000 pounds
68 SWB Fleet 383
Old 07-30-2011, 02:15 PM   #15
BENC-10
Re: Towing????
Yea that's what they told me too...So i drove the thing home!!!
I appreciate the help though guys, I'll see if i can get a picture up later
Old 07-30-2011, 02:19 PM   #16
71meangreenc10
Re: Towing????
Nope, fit fine.
Smitty
71 C30 Wrecker
