Old 07-29-2011, 04:36 PM   #1
frankyjoet
Red face 73gmc aftermarket pushbutton starter
Hi, I bought this Pilot perf. remote starter. Am having a problem with the directions, which are fairly easy to understand. Problem is what ign wire do i select from the ign sw "PLUGS". There are 2 ign power wires RED - 1 ign wire BROWN. They are in 2 different PLASTIC plugs. 1 is blck the other clear.
I have the steering column laying on cab floor, the ign sw is attached and the PLUGS are in the ign sw. I tested the red power wire on the relay with a trouble lite and power is going to the PUSHBUTTON RELAY. All you have to do, if everything is hooked up correctly, is to turn key on then press the start pushbutton. Nothing happens. I am getting 12v directly from battery. That is where i am at this time. The battery was low, so am charging at this time. I know you need a lot of amps to start. Could this be a problem. Would like any suggestions. Thanks in advance. Frankyjoe 73classic. I don't know how to dwnload a pic of my truck. Any suggestions.
frankyjoet is offline   Reply With Quote
Old 07-30-2011, 12:32 PM   #2
slimneverdies
slimneverdies's Avatar
Re: 73gmc aftermarket pushbutton starter
I dont have any helpful information to share but would love to see a pic of this setup. Does this pushbutton start have any anti-theft features to make it hard to steal?
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 07-31-2011, 08:44 PM   #3
frankyjoet
Red face Re: 73gmc aftermarket pushbutton starter
Hi Slim, found the problem. I would say having a push button setup is a
security method for theft. The kit has only 4 wires and you can hide the relay and push button. It's not expensive, you can see it on Amazon. Do you know how to dwnload pics to this site. Hope this helps. joeyt
Old 07-31-2011, 09:41 PM   #4
slimneverdies
That sounds cool. Here is a link to post pics http://www.67-72chevytrucks.com/vboa...b3_attachments
Long live SLIM
