Old 07-29-2011, 07:00 PM   #1
jbarnes67
Direct Sheetmetal Firewall
Has anybody installed one of these on our series of trucks? If so what was the quality, and fitment issues? How much more clearance was really gained?
James
jbarnes67 is offline   Reply With Quote
Old 07-30-2011, 01:42 PM   #2
mbgmike
Re: Direct Sheetmetal Firewall
James
never installed one but we sell the panel mentioned and all their products. only thing I have installed is their floors. We have never had a customer call or say anything good or bad. floors installed pretty straight forword
mbgmike is offline   Reply With Quote
Old 07-30-2011, 04:14 PM   #3
kieth
kieth's Avatar
James
pictures?
kieth is offline   Reply With Quote
Old 07-30-2011, 07:44 PM   #4
wildearp
wildearp's Avatar
Why do you need more room?
Here is the pic from their website:
If you have a metal brake, you can fab that up in a couple hours.
wildearp is offline   Reply With Quote
Old 07-30-2011, 08:08 PM   #5
jbarnes67
I would like more room to be able to push my big block back another inch, so as to have more room between the electric fan and the GM serpentine belt system I have.. I would like to also smooth out the firewall, because previous owner liked to test his drill and hole saw out on the factory firewall. It is not a do or die thing to swap the firewalls, just curious to know the quality and benefits.
Old 07-30-2011, 10:54 PM   #6
wildearp
wildearp's Avatar
Direct makes a good product. It would probably be a good idea to give them a call Monday morning. I wonder why the trans cutout isn't uniform in the photo....
Direct started as direct competition to *****in Products. There is some history/drama there, but both companies have been around for quite a while. I used *****in for my Model A firewall.
The forum censored a manufacturer name. Unbelievable. It sounds like Kitchen with a B. More like Beeotching. B!tchen.
Old 07-31-2011, 01:30 AM   #7
ConnDemned
Actually the stock trans tunnel isn't uniform, maybe for linkage clearance?
to OP, I look at using one of those but for the money I just made my own, p.o. cut the firewall for clearance. I saw a build thread somewhere on here I believe using a wheel barrel for the indent.
ConnDemned is offline   Reply With Quote
Old 07-31-2011, 01:49 AM   #8
Mike Bradbury
Mike Bradbury's Avatar
Dave at direct sheet metal is a great guy and stands behind all of his work. he has made a lot of the panels for the '29 ford roadster p/u that I am working on and have never been unimpressed. I am lucky to live in El Cajon where I can just drive down to his shop, or a little bit further to B!tchen products.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 07-31-2011, 10:47 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
Here is what I did to get my BB back farther. I didn't cut the pieces out of the firewall just 3 sides and bent them inward and filled the rest with an old bed front I had. http://www.67-72chevytrucks.com/vboa...d.php?t=259536
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
