Old 07-29-2011, 07:42 PM   #1
kris's66lwb
resident wrencher
bed cover
i was thinking about building a bed cover that fits flush with the bed rails and not on to of the bed what all would i have to do to accomplesh this
kris's66lwb is offline   Reply With Quote
Old 07-29-2011, 08:21 PM   #2
canadian trucker
A day should have 30 hours.
Re: bed cover
http://67-72chevytrucks.com/vboard/s...d.php?t=420381
canadian trucker is offline   Reply With Quote
Old 07-29-2011, 08:21 PM   #3
80streetcoupe
Re: bed cover
You could bolt on some 1inch angle iron to your bedsides and use 3/4inch plywood as a base. Then some 1inch foam for padding, then cover it with some vinyl. Then, if you wanted to make it permanent to the box, just drill some holes thru the underside of the angle iron, then secure some woodscrews into the plywood.
Or if you wanted to hinge it, use a heavy duty piano type hinge across the front bed panel or half way down the cover, if you so decided.
Just my 2 cents. Hope this lil idea helps you out, if that's the route you want to go.
80streetcoupe is offline   Reply With Quote
Old 07-30-2011, 11:00 AM   #4
kris's66lwb
resident wrencher
Re: bed cover
80 coupe thats a greath idea thanks
Old 09-23-2011, 07:20 AM   #5
Pop's C-10
Pop's C-10's Avatar
Re: bed cover
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
