Old 07-30-2011, 01:27 PM   #1
ubtripn
ubtripn's Avatar
Slight crank pulley wobble question
Hi all, I want to thank everyone forst for all of the help over the past couple of days. I am almost there, the last problem this engine seems to have is a slight wobble on the crank pulley. (engine is a 69 350). Should I replace the pulley? or replace the both the pulley and the harmonic balancer? and has anybody ever done this with the fan on?
thank a million
ubtripn is offline   Reply With Quote
Old 07-30-2011, 03:49 PM   #2
Wrenchbender Ret
Re: Slight crank pulley wobble question
If its an aftermarket pulley they often dont fit good. The original one just may not be seated good. Loosen it up & move it & tighten it evenly a little at a time. Or remove it & turn it to a different mounting hole. It doughtful that it is the balancer.
Wrenchbender Ret is offline   Reply With Quote
Old 07-30-2011, 03:56 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
You will have to replace the balancer. There is a rubber insert in them that goes bad and allows the balancer to go out of alignment.
LockDoc
Leon
Old 07-30-2011, 04:28 PM   #4
ubtripn
ubtripn's Avatar
I will do both, thanks guys. Now is the where exactly is this rubber insert?
I am fairly certain it is original equipment.
Old 07-30-2011, 05:07 PM   #5
LONGHAIR
The simplest test is to remove the pulley and start it up. If the balancer has the wobble too, it needs to be replaced. If the wobble is gone, you have the bent pulley already removed, so you can match it up to a replacement.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-30-2011, 06:16 PM   #6
Wrenchbender Ret
The balancer has an outer ring & the center hub section. There is a rubber insert holding them together. The pulley is bolted to the center section & crank. If the rubber is deteriated & the outer ring has shifted it would not make the pulley wobble. When removeing the balancer do not use a puller that wraps around the outer ring. Use a puller that uses the taped holes in the balncer. If the rubber looks good & the outer ring is on the same plane as the center (ie has not shifted back or forward) it should be OK. If you use the timing marks for setting the timing & it doesnt seem to time right its posible the outer ring has turned on the balancer.
Old 07-31-2011, 09:45 AM   #7
ubtripn
ubtripn's Avatar
Great information! Many thanks.
