Old 07-30-2011, 06:39 PM   #1
oklaoz
How to restore side trim?
The side trim on my 71 is in pretty good shape,but the shinny part is cloudy.Is there a good way to restore the shine?
oklaoz is offline   Reply With Quote
Old 07-30-2011, 07:06 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: How to restore side trim?
The cloudiness you see is actually the anodized outer surface that has oxidized.
First steps are to get below that layer plus massage out any damage.
Followed by buffing to a luster.
Finished by protecting the new surface.
The process can be very time consuming but can save a bundle besides being gratifying.
The above is an over simplified explaination...
This thread will help explain the process further.
There is more than one way to remove the anodized layer
and I'm sure we will get more folks chiming in.
ETsC10 is offline   Reply With Quote
Old 07-30-2011, 07:38 PM   #3
Dunenutt
Newbee
Dunenutt's Avatar
Good luck! It's a time consuming tedious process. I gave up restoring it, and painted it. Now I dont like it, and going to do it all over.
Dunenutt is offline   Reply With Quote
Old 07-30-2011, 10:45 PM   #4
DT1
DT1's Avatar
I restored mine last year. It's a very tedious task.
The first thing to do is to strip the anodizing. The best method is to use a 10% solution of sodium hydroxide (Lye) and water in a plastic spray bottle. Make sure you wear eye and skin protection if you use this method. Lye will burn the hell out of your skin and can cause irreparable damage to your eyes!
Use a Scotch-Brite pad to help loosen up the anodizing and repeat if necessary.
When all of the anodizing is off, all of the dings and dents have to be removed.
The most effective way I've found is to set each trim(Molding) piece on a small piece of plywood covered with a towel and use a screen door roller to message them out. Then you will need to sand them smooth. A Sonicrafter type sander worked really well for that. After each piece is smooth and straight, it's time for the buffing wheel. I started by cutting 6 inch discs from red Scotch-Brite pads and tripled them up on the buffer. I found this method works well for obtaining a smooth, consistent surface for final buffing. For the final buffing, I used a Denim wheel and black cutting compound. It takes a lot of patience but eventually each piece will return to it's original luster.
When all that is done wipe each piece down with lacquer thinner to remove any residue. All you have to do now is re-anodize or paint with a good automotive clear coat and repaint the black. I used SEM Trim Black and followed up with clear. Oh Yea...After I painted the top moldings, I realized I had done them improperly and had to strip the paint off and redo them correctly.
Before:
After:
DT1 is offline   Reply With Quote
Old 07-31-2011, 05:09 AM   #5
67chevy1series
67chevy1series's Avatar
man i feel bad for the guys with 69 72 trim its so FAT and mines so small/skinny lol
67chevy1series is offline   Reply With Quote
Old 07-31-2011, 09:22 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
DT1....good, short "How To". There are others, but yours rang a bell with me. Using the screen tool (the roller on a handle) makes good sense.
My project is my grille. I'm thinking a sand bag (body type) would also be a good thing to support the work piece.
Member Nr. 2770
Old 07-31-2011, 10:50 AM   #7
DT1
DT1's Avatar
The grill can be done the same way. A sand bag will probably work fine. I had to make some special dent removal tools out of plastic rod but I also used the roller.
Old 07-31-2011, 04:36 PM   #8
oklaoz
Cool! Getting the anodize off is the key info I needed. Thanks.
Old 07-31-2011, 04:47 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
There was a post on here about the value of an NOS grille surround for a '71-2. The seller wanted $500 for it. I spoke with a guy 2 years ago about restoring my grille. He wanted $500. I bought a wheel polishing air tool from Sherwin-Williams, for $105. Same tool (identical) thru Eastwood is $130. Do the math.
Member Nr. 2770
Old 08-02-2011, 08:05 PM   #10
oklaoz
What kind of store sells lye?
Old 08-02-2011, 08:23 PM   #11
OhOneWS6
OhOneWS6's Avatar
http://candleandsoap.about.com/od/co...lyesources.htm
OhOneWS6 is offline   Reply With Quote
Old 08-02-2011, 09:00 PM   #12
wicky
wicky's Avatar
Do u have any pics of the tools u made. My trim has a lot of dents in the corners. I was thinking of using a small sand bag and something that would resemble a chisel but made out of wood or plastic?
wicky is offline   Reply With Quote
Old 08-02-2011, 11:07 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
wouldnt oven cleaner work the same (pretty much lye)
John
1999 Toyota Tacoma 4x4
Old 08-02-2011, 11:19 PM   #14
70cst
70cst's Avatar
Interesting thread ... Good info.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-03-2011, 12:46 AM   #15
sanford66
sanford66's Avatar
Originally Posted by DT1 View Post
Before:
After:
Wow, i can't believe this difference between the before and after! Are you sure they are the same moldings? Just kidding. Very nice work and info! Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
