Old 07-30-2011, 07:04 PM   #1
Sven
Sven's Avatar
Lift springs
I want to lift my 1969 4x4 by 3-4" and I dislike lift blocks. My springs are original and seem a little tired. So, to kill both birds I want to buy replacement springs with a 3-4" lift built in. Anyone know where to get such a beast? Tried emailing Rough Country, who make a lift with front springs and rear blocks but seem to have rear springs as an option, but I get no reply.
Second question is about shocks. Anyone know what shocks I'd need for such a lift?
In case you're interested, other projects in the pipeline are:
Convert to EFI using a TB, later computer controlled dizzy and a MegaSquirt
Later convert to propane (maybe)
Replace the axles for stronger and disk brakes, but not sure which yet
Replace the heads for aluminum (lighter/better flowing)
Replace the junkyard TH350 with a 700R4
Blast/powdercoat the wheels and replace the rusty wheel studs
I should do a build log here, eh?
TIA,
-Steve
1969 Chevrolet 4x4 C10 Pickup
Sven is offline   Reply With Quote
Old 07-30-2011, 07:32 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Lift springs
Lots of sping company's will make custom springs. I know "Riteway Spring Co." here in Tacoma, WA makes any custom spring you need. Whether it's leaves, coils, or torsion bars... lifted or lowered... they can do it.
But I'm sure there are lots of kits available through mailorder. You just gotta do some diggin'.. Check with National Tire and Wheel. They always have lift kits lifted in all the popular 4X4 magazines. I have bought a few lift kits from them myself over the years.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-30-2011, 09:55 PM   #3
Sven
Sven's Avatar
Re: Lift springs
Thanks Gary,
Great tip! Here's what I need probably:
4" Lift with Shocks
Also, right after posting I found a complete 4" Tuff Country lift that comes well recommended, but it's significantly more expensive than the Rough Country kit. That should fix me up, but I'll dig around some more too ...
-Steve
Old 08-03-2011, 04:29 PM   #4
Sven
Sven's Avatar
Re: Lift springs
Having looked around, National Wheel & Tire even seem to have the best prices ... thanks man!
Purchased. Costs $599+$50 shipping to Arizona.
-Steve
Old 08-03-2011, 04:39 PM   #5
onebadbowtie
onebadbowtie's Avatar
Re: Lift springs
you can get the rough country lift with new rear springs.....just scroll down farther and you have 3 options...blocks, 52 inch rear leaves, and 56 inch rear leaves. or you can just call them. i always have good luck talking to them. they seem to know there stuff
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 08-04-2011, 12:16 AM   #6
84scottsdale
Re: Lift springs
Did you look at the suspension special from national tire its less than $500 for lift springs front and rear plus shocks. Thats what i did qnd it was a superlift. It came with every thing u need for the lift, too. And if you add shock boots u get $50 shipping.
1969 gmc k2500 project
84scottsdale is offline   Reply With Quote
Old 08-04-2011, 01:09 AM   #7
Sven
Sven's Avatar
Re: Lift springs
Thanks Man, I'll call NW W&T tomorrow and change my order. Thanks again ...
-Steve
Old 08-04-2011, 01:43 AM   #8
84scottsdale
Re: Lift springs
Ya, no problem thats why we all join this board.
Old 08-04-2011, 01:44 AM   #9
84scottsdale
Re: Lift springs
Double post
Old 08-04-2011, 09:20 AM   #10
1972RedNeck
1972RedNeck's Avatar
Re: Lift springs
Summit Racing has them.
Why do you dislike blocks?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-04-2011, 09:30 AM   #11
CG
BlahBlahBlah
Re: Lift springs
There is a whole 4x4 section of the board devoted to us guys with 4x4's
http://67-72chevytrucks.com/vboard/f...splay.php?f=30
Old 08-04-2011, 11:09 AM   #12
Sven
Sven's Avatar
Re: Lift springs
The special is on backorder, they said they haven't had them in stock for 6 months. I guess my Rough Country order stands.
-Steve
