Old 07-30-2011, 08:55 PM   #1
reecetas7196
Exclamation 69 C20 Longbed Drum Brakes not working??
Ok I went to change my front half moons on my drum brakes only to find that they were in good condition. My brakes haven't been working well and I thought that maybe it was because the pads were worn out and needed changed. I mean I have to push the brake pedal to the floor and even then it still doesn't engage at all, but some how I manage to stop its just slow stop. Anyway, I found out that the front drums were not engaging at all and the back drums were some but not enough to stop well without having to smash the pedal down to the floor and creep to a stop. Does anybody have any input as to what may be the problem? It would be greatly appreciated bc stopping is a key factor in driving! lol
Also my emergency break isn't work either. It won't press down and engage at all. This all is pretty frustrating so any help would be greatly appreciated!!! Thanks guys,
Joe
reecetas7196 is offline   Reply With Quote
Old 07-30-2011, 09:07 PM   #2
Daddy Brim
Daddy Brim's Avatar
Re: 69 C20 Longbed Drum Brakes not working??
This is what I learned from my first brake job on my 67 C-20. You need to turn the adjustment screws until tight ( you can not turn the drum ) then back them off until you can just turn the drums. You should get a good firm peddle and lots of brake.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 07-30-2011, 09:50 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
pictures would be nice
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-31-2011, 10:59 AM   #4
eagleuh1
eagleuh1's Avatar
x2. On adjustment screws. You can also adjust the parking brake cable after doing the screws. And then I'd bleed the brakes again also. Hope some of this works for you. Jim
eagleuh1 is offline   Reply With Quote
Old 07-31-2011, 12:37 PM   #5
reecetas7196
when you say adjust theparking brake do you men underneath where it splits to both back brakes? I've tried that and loosened it up pretty much all the way and my PB is still stiff and won't work.
Old 07-31-2011, 01:13 PM   #6
cdowns
cdowns's Avatar
i've found lubricating moving parts makes them work better as far as your parking brake goes// the ratchet in the cab and the able coming out of the backing plate in the rear are the two main areas that should b lubricated and moving easily
like others have said try bleeding all 4 corners of the brake system// also adjust out the shoes so there is very slight dragg on the drums
Old 08-01-2011, 07:22 AM   #7
eagleuh1
eagleuh1's Avatar
Yes, thats what I meant. I've never tried lubricating the cable, but that sounds like something smart to do. Especially seeing how rusty some of these trucks can be. It sounds like your cable or handle might be bound up if you've loosened the cable and the handle is still stiff. Jim.
Old 08-01-2011, 11:11 AM   #8
reecetas7196
I'll try luging the cable today to see if it helps the PB
