Old 07-30-2011, 11:04 PM   #1
1971k567cam
1971k567cam's Avatar
383 stealth ram and 700r4 swap
Well the engine and headers are in still have some wiring and fuel line pluming to do before trans is put in then i get to weld up some 3 inch exh with x pipe.
1971k567cam is offline   Reply With Quote
Old 07-31-2011, 12:00 AM   #2
joemacho
joemacho's Avatar
Re: 383 stealth ram and 700r4 swap
thats nice mangs
1972 gmc jimmy project comin soon ( jus a sin )
1959 chevy apache shortbed fleetside (brsgrm)
1966 Chevy c30 duallie 2wd (big chief)
joemacho is offline   Reply With Quote
Old 08-02-2011, 01:00 AM   #3
1971k567cam
Well it runs i fired it off today now just need to finish install and weld up exh.
Old 08-04-2011, 01:39 AM   #4
1971k567cam
Trans transfer case and all lines in test drove open headers today shift points off a bit just need more adjusting on tv cable but hp/tq 3 times the old engine trans setupso off to the exh shop tommorow for x pipe and flowmasters BTW soft top should be here on friday
Old 08-06-2011, 01:32 PM   #5
1971k567cam
So engine and trans swap is done exhast turned out good and installed soft top after work last night. Btw the instuctions for these things might as well be in spanish for me they dont help at all and the self tapping scews for header are more like self distructing have to go to a boat shop and get some more. Also think i want to move side rails out further to the edge but all in all quality stuff.Name:  2011-08-05_19-51-22_414.jpg
Old 08-07-2011, 07:33 PM   #6
SeventyOne
Did you move the engine forward or the Tcase back to fit the 700r4? What headers did you choose?
SeventyOne is offline   Reply With Quote
Old 08-07-2011, 08:34 PM   #7
1971k567cam
Moved engine forward 1 5/8 just redrilled the frame. Btw the frame springs out when you remove front crossmember so account for that when you drill. I got a set of headman headers off a guy from work out of a newer k5 fit pretty good had to dimple the passenger side header by the front shackle it rubbed a bit. Price was right 40 bucks sand blasted them and painted them with som vht seams to be ok for now.
Old 08-08-2011, 08:25 PM   #8
SeventyOne
Got pics and part numbers?
Old 08-15-2011, 04:46 PM   #9
rsavage
rsavage's Avatar
Nice conversion.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
