Old 07-31-2011, 12:17 AM   #1
towersddg9
towersddg9's Avatar
PWR STR hose ?
Need some help on running these power steering lines here are some pics of my set up, I do know the large 10an from remote resivoir goes to the 10an port on the pump, question is does anyone know where to run the others
towersddg9 is offline   Reply With Quote
Old 07-31-2011, 01:34 AM   #2
Captainfab
60-66 Nut
Re: PWR STR hose ?
It looks to me like you need a line from the reservior to the intake on the pump, Then another hose from the pressure side of the pump to the steering box, and then your return line goes from the steering box back to the other port on the reservior
Old 07-31-2011, 01:40 AM   #3
towersddg9
towersddg9's Avatar
Re: PWR STR hose ?
Thank You Capt
Old 07-31-2011, 02:47 AM   #4
shortbed70
shortbed70's Avatar
Re: PWR STR hose ?
Post 428 in my build shows how mine is done. I have a big feed line off the bottom of the resi going to the matching port on the pump then small line out to box. Im not sure if mine are in the right orientation but my pressure line goes to the furthest port and the return. Goes back to resi.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-31-2011, 08:56 PM   #5
TR65
TR65's Avatar
Re: PWR STR hose ?
Just to be clear.
The output of the pump (the small line) goes to the P/S box port closest to the frame. It has a bigger thread than the other port to prevent mix-up. This is the high pressure line, has to be special hose for the pressure.
The other port from the P/S box is the return and goes to the small fitting on the reservoir.
The big line from the reservoir is the pump suction line.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
