Old 07-31-2011, 02:27 AM   #1
whitelightnin92
72 rat project
picked this truck up, already posted some pics in my 69 build thread but i figured i would start a thread of its own
put a seat in it today. it had nasty buckets. i got some satin black paint and wire wheeled the floor and painted it. not very happy with it so im going to go back and hit it with flat black. i want to get door panels to match the seat. also have to go to the junkyard and find matching seatbelts.
i need to paint the outside all flat black too. only half if it is flat right now. i just want it to look halfway presentable for now, later on i will fix the body.
06 ECSB 4X4 L33 HO 3.73s 15.56@89.9 STOCK
92 K1500 TBI350vortec(too much to list)
69 C10 short fleetside(under construction)
72 C10 short stepside(almost driveable)
whitelightnin92 is offline   Reply With Quote
Old 07-31-2011, 02:30 AM   #2
whitelightnin92
Re: 72 rat project
you can see i didnt finish painting the dash because i didnt like it, and i needed to tape it off anyway. i will get some flat black paint tomorrow. the little 355 in this truck will really run. i wasnt expecting it to run so good with stock heads on it. i need a driveshaft before it goes very far tho.
Old 07-31-2011, 07:04 AM   #3
Krooked Kustoms
Krooked Kustoms's Avatar
Re: 72 rat project
Looks like a good start mate, what's the plans for it?
Krooked Kustoms is offline   Reply With Quote
Old 07-31-2011, 03:46 PM   #4
whitelightnin92
Re: 72 rat project
going to try and keep this one driveable and resist the urge to tear it apart. im going to 2/4 drop it. do red wheels with white walls. keep it very simple. i need to collect little things like interior pieces. lights. ect. i am going to put front and rear roll pans on it. main reason being to put tail lights in. im keeping the truck flat black. not going to mess with much body work for now.
also need to rewire most of the truck, its been hacked terribly. i need to pull the column apart too. the right turn signal stays blinking and the lever moves freely on the column. im assuming it came apart inside?
Old 07-31-2011, 09:57 PM   #5
whitelightnin92
Re: 72 rat project
need to get a driveshaft for it. got the brakes working, someone replaced a line and never put fluid back in or bled them
Old 08-01-2011, 12:53 AM   #6
lowdown72
lowdown72's Avatar
Re: 72 rat project
welcome to the board looks like a good start keep it up
72 c-10 67 clipped 327 th400
lowdown72 is offline   Reply With Quote
Old 08-01-2011, 01:01 AM   #7
whitelightnin92
Re: 72 rat project
thanks, and will do
Old 08-01-2011, 01:03 AM   #8
lowdown72
lowdown72's Avatar
Re: 72 rat project
what u got planned for it
Old 08-01-2011, 01:17 AM   #9
whitelightnin92
Re: 72 rat project
simple and unique. i dont want alot of money tied up in it, just want to have alittle fun with it while im restoring my 69. im planning on a budget of $4000 . i bought it for $2000 so that leaves $2000 left. main things i want to do is
one piece driveshaft(old one is literally about to fall out of truck)
fix wiring
find interior pieces(going for red/black theme)
flat black exterior with red wheels/white walls
2/4 drop
engine/trans are in great shape
already has 14 bolt 3.73 posi rear.
mechanically were good to go just need cosmetics
also, it needs a stall badly. too much cam in it for stock stall
Old 08-01-2011, 01:31 AM   #10
lowdown72
lowdown72's Avatar
Re: 72 rat project
sounds good cant wait to see the updates
Old 08-07-2011, 10:19 PM   #11
whitelightnin92
Re: 72 rat project
rebuilt another edelbrock i had laying around and changed the metering rods and jets up. i got rid of most of the hesitation it had, smoothed the idle out and picked up a good bit of HP. . biggest thing is it needs a stall badly. i need to buy a bigger accelerator pump nozzle for it and it should be good to go. she runs a bit warm so i need to figure that out. the guy threw in a redone radiator in the bed. i may put it in but first im going to check out the T-stat
Old 08-08-2011, 12:02 AM   #12
whitelightnin92
Re: 72 rat project
anyone know this casting mark? i was going to pull a valvecover and check the numbers but i didnt get that far
Old 08-08-2011, 12:44 AM   #13
whitelightnin92
Re: 72 rat project
i think theyre just the original 72 350 truck heads, i have a nice set of camel humps in the garage... hmm. i think it would put out a good bit more hp with the camel humps. its already over 300 easily. id say it will easily run 14s now.
Old 08-09-2011, 02:00 AM   #14
whitelightnin92
Re: 72 rat project
well guess if noone knows what they are im going to pull a valvecover this weekend
Old 08-09-2011, 02:23 AM   #15
Krooked Kustoms
Re: 72 rat project
Plans sound good mate, I'll be watching this one. Do you know if you can run a one piece shaft on a lwb with a 4/6 drop?? Looking at doin that with mine. Any help would be great. Cheers
Old 08-09-2011, 02:59 AM   #16
whitelightnin92
Re: 72 rat project
as far as i know you can. you just can't use the big aluminum ones
Old 08-12-2011, 02:55 AM   #17
whitelightnin92
Re: 72 rat project
ok guys help, i can get a good deal on a hurst Vmatic shifter. my concern is it will be too short. its 11.65 in. will the shifter be too short or no? i guess worst case scenario i could lengthen it. need to know, guys bringing it to work with him in the morning for me to look at
Old 08-12-2011, 04:10 AM   #18
whitelightnin92
Re: 72 rat project
oh hell, ill take it lol
Old 08-18-2011, 02:27 PM   #19
whitelightnin92
Re: 72 rat project
bought some red paint for the wheels today and got some flat black for the body. interior is all painted. pics this weekend possibly
Old 09-19-2011, 11:10 PM   #20
whitelightnin92
Re: 72 rat project
painted and cut 1 coil out of the front. i have 4 inch springs waiting for the back.
Old 09-19-2011, 11:10 PM   #21
whitelightnin92
Re: 72 rat project
i need to repaint the hood but the rest looks great
Old 09-19-2011, 11:27 PM   #22
lowdown72
lowdown72's Avatar
Re: 72 rat project
trucks lookin great thats some good progress keep it up
Old 09-20-2011, 05:07 AM   #23
Krooked Kustoms
Re: 72 rat project
Looking good mate. Did you end up getting that shifter?
Old 09-20-2011, 09:52 AM   #24
whitelightnin92
Re: 72 rat project
long story short, no. i am getting one tho.
Old 09-21-2011, 07:58 PM   #25
quandelgarage
quandelgarage's Avatar
Re: 72 rat project
nice, i dig it .
old school like your mother.....
My Build--- Body dropped 67 service truck http://67-72chevytrucks.com/vboard/s...d.php?t=485504
quandelgarage is offline   Reply With Quote
