Factory fan shroud
I'm having zero luck,figured i'd ask you guys!
I need a fan shroud for my 62' & am running a small block.Are passenger car(60-64?) fan shrouds compatable? I'm assuming(here's where I get in trouble!) they came w/ a fan shroud, right? I'm definitely not going to run a fiberglass job, & although I own an electric fan that will work, I just prefer a good old fashioned metal shroud. Thanks. Last edited by Blue Blood; 07-31-2011 at 09:18 AM. Reason: ... |
Re: Factory fan shroud
im not sure the trucks came with a metal shroud ? i bought a plastic type one from brothers trucks that fit perfect, but i could be wrong on the metal ones????
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
I've got one from a 66 with an inline 6. Anyone know if it's the same?
Posted via Mobile Device |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The '60-'62 fan shrouds are metal and sort of resemble a short piece of culvert.
The '60-'64 passenger car shrouds may be close enough that you could modify one to fit. I know the radiators are very close in size.
so capt what did the 63-66 come with as far as shrouds?
I was thinking that,I owned a 64' belair & had to buy a shroud for it,& it dawned on me that that might work,they even had 3 sets of holes on each side..
I know the frames differ after 62' ,but maybe all the radiator core supp./sheetmetal up front is the same? (could I be that lucky?) The ID on the fan i'd assume is the same as a 8cyl setup,that wouldn't be an issue for me if not though, i'd just run a different size fan if need be.
1961 crewcab
I have a 66, it is some sort of fiberglass composite plastic.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Custom Builder
![]() Join Date: Jun 2003
Mine is the same on my '66!
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
#11 | |
Bob |
#13 |
60-66 Nut
Jon is correct. I don't know exactly what they are made out of, but the original ones can be repaired with fiberglass. The '63-'66 V8, and HD I6 fan shrouds are the only ones that are reproduced.
#14 |
![]() Join Date: Aug 2008
The V8 ones are similiar to a Bakelight material. Original ones are kinda tough to find.
