Old 07-31-2011, 11:46 AM   #1
flatbed51
flatbed51's Avatar
Rust Penetrants Test Results
This may be old news to some but I thought I would pass it along.
I was in a friend of mine's machine shop the other day, and he hands me the following article to read.
Machinist's Workshop magazine tested penetrants for break out torque on rusted nuts. They arranged a subjected test of all popular penetrants, with the control being the torque required to remove the nut from a "scientifically rusted" enviroment. The results are as follows:
Pentrant........ Torque
None 516 lbs.
WD-40 238 lbs.
PB Blaster 214 lbs.
Liquid Wrench 127 lbs.
Kanp Kroil 106 lbs.
ATF/Acetone 53 lbs.
The ATF/Acetone mix was a home brew of 50% Automatic transmission Fluid and 50% Acetone.
Because Acetone evaporates rapidly, the shelf life of this product may be rather short.
After reading this article, I looked to my friend and asked if he had tried it, and did it work. His response was with a big smile. He said he had never seen anything do such a good job.
I have not tried it myself yet, but I am going to give it a go.
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 07-31-2011, 11:51 AM   #2
mbgmike
Re: Rust Penetrants Test Results
cool
mbgmike is offline   Reply With Quote
Old 07-31-2011, 01:17 PM   #3
63 & 64 Bowties
and a few others
That was mentioned here about a year or so ago. Same article. Same magazine. Here: http://www.67-72chevytrucks.com/vboa...d.php?t=395612
I've been using it ever since.
Works great. Just doesn't smell too great
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
Last edited by 63 & 64 Bowties; 07-31-2011 at 01:21 PM. Reason: felt like havin' a peanut butter & jelly sandwich
63 & 64 Bowties is offline   Reply With Quote
Old 07-31-2011, 03:43 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
I use this very often but only outside. The fumes are bad in a closed space and can cause you to pass out. Using a torch on a bolt that has been prayed with acetione causes toxic and caustic fumes, not so good for the lungs and eyes.
It will damage paint, plastics and will also ignite with a spark and It will surely soften up the soles of your boots and leave foot prints on the kitchen floor.
It does work very well just be careful when using it.
dwcsr is offline   Reply With Quote
Old 07-31-2011, 07:30 PM   #5
OrrieG
OrrieG's Avatar
BBOMN when I read that. Another big no no is heating brake parts cleaner that is liquid, a search on line will turn up a guy that has permanent neuro damage after cleaning a part and hitting it with a torch, apparent releases a chemical akin to nerve gas. Be careful guys.
OrrieG is offline   Reply With Quote
Old 07-31-2011, 07:35 PM   #6
Dan in Pasadena
Dan in Pasadena's Avatar
Question for those that have tried the ATF/Acetone mix: How do you apply it?
My first thought is an old fashioned oil squirter. Which seems like it would work fine BUT the acetone would evaporate away in storage, so....do you store it in a close container then transfer it when you want to use it?
The only big surprise to me is that old fashioned Liquid Wrench worked as well as it did.
Dan in Pasadena is offline   Reply With Quote
Old 07-31-2011, 08:05 PM   #7
63 & 64 Bowties
and a few others
that's exactly how I do it. Old fashioned squirt can.
And, if it's evaporated, I can't tell. The can may not be completely air tight, but it's not open to the atmosphere either.
Old 07-31-2011, 08:31 PM   #8
Dan in Pasadena
Bill,
First: A heartfelt thanks for your service, AND I agree with Gandhi's quote. Our moral "progress" doesn't seem to be getting better lately but then again it MAY just be the 24hr newscycle and the insatiability of the millions of news "outlets" that has us thinking so.
Second, after I got to thinking about my post I thought, "What's the big deal? Stick a little piece of masking tape over the squirter tip and pull it off when you use it"
Old 07-31-2011, 11:19 PM   #9
mr48chev
mr48chev's Avatar
Acetone is pretty much the same stuff as your wife/girlfriend's nail polish remover. And that stuff will eat up or damage a lot of things including tile floors.
Which reminds me, there was a reason why I wanted to save that shampoo bottle with the
flip up spout that is almost empty.
Old 07-31-2011, 11:55 PM   #10
mknittle
mknittle's Avatar
That was a reaction with argon gas tig welding
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-01-2011, 06:30 AM   #11
mbgmike
did you pass out David?
Old 08-01-2011, 07:28 AM   #12
63 & 64 Bowties
and a few others
Bill,
Thanks Dan
Be careful, acetone will melt some plastics.
My Stepdad made handmade guitars and fiddles back in his day. And, I remember him telling me that he used acetone to melt toothbrushes to make the colored dot thingies in the frets of guitars. Sorry if I'm not describing that right, I'm not a musician.
Old 08-01-2011, 10:55 AM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
I did not acutally pass out but lets say it was an unscheduled sit down.
