GobbleStalker Calls
![]() Join Date: Aug 2010
WTB 1967, 327 air breather
I need an airbreather for a 1967 327 engine. I also could use the riser.
I can have it shipped to 13601 NY state or Canada. Could use some carb identification also please. My carb has these markings on it. RP 2 Jet 7029110 285CH81 Thanks Kevin
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) Last edited by GobbleStalker; 07-31-2011 at 03:21 PM. |
![]() Join Date: Apr 2003
Re: WTB 1967, 327 air breather
carb is from a 1969 chevelle, camaro, nova . with auto trans
GobbleStalker Calls
K with that said I need to verify my block? Where can I find the numbers on it? I was told this truck had original 327 engine in it.
Thanks for any help.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
"Junkyard Dog"
![]() Join Date: Jan 2008
There is pad on the block just in front of the passenger side cylinder head. Post the info that is stamped on that pad and I'll ID it for you.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
GobbleStalker Calls
Pad is blank. Looks ground off.
GobbleStalker Calls
Just to be clear I need a 2 barrel breather and riser.
i know i have a 67 283 2 barrel air cleaner , it should be the same. it will be this weekend before i can look for the riser. if i can find the riser $30 plus shipping.
check the casting # on the drivers side rear of the block where it meets the trans. and see if you can find the date code, also at the back of the block , usually on the pass side behind the dist. |
GobbleStalker Calls
Please let me know.
Thanks Kevin
