31 Gallon Suburban Tank
Has anyone used a '73 - '91 31 gallon suburban tank in one of our trucks? LMC lists the dimensions as 28 3/4" X 28 1/8" X 12 3/4". Here is the LINK. This is for my longbox with a 4"lift.
Also, does anybody know if the sending unit ohms are the same? |
Re: 31 Gallon Suburban Tank
I used one off a fuel injected suburban and the fuel sending ohms were the same.
same here, got a 31 gallon tank out of an 88 fuel injected big block burb in mine, just changed the sending unit to a non fuel injected one from a 76 small block burb. and yes the ohms are the same. also i had to remove the 2 rear most cross-member as they were in the way on mine (also cause im bagged), you may only need to remove the one at the very back and replace it with a home made one farther back like i did. also the fuel filler line is on the wrong side, but you can just turn the tank around so its on the right side
