can i fix this exhaust manifold
I'm not sure if it'll seal properly or not anymore so I'm wondering if I can resurface them or do I need to find a new manifold? Or is there a way to make sure they'll seal properly?
Thanks ![]() ![]() Posted via Mobile Device
1969 Chevy c20(Miss Hackjob) |
Re: can i fix this exhaust manifold
Looks like there is still gasket stuck on them to me.
The Older Generation
That looks like part of the old gasket on there. Rap on it a little bit with a small hammer and see if it flakes off or take a small angle grinder to it. Just go easy. I think it will clean up. LockDoc
I'll try that tomorrow guys an let you know how it goes
I wonder how much it would cost or if it were possible to have a machine shop deck a set of these. I would go with an angle grinder with a 120 grit flapper on it and see if it will even out.
^^^ I was wondering that to. I also thought about the grinder, just don't want to ruin them
Cruzin
i agree looks like gasket on there still. On stock manifold i don't even use gaskets and they do fine.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
^^^ wouldn't they leak though?
I would take a grinder to them and clean up the surfaces, not so much grind metal off but clean the surface and get rid of the old gasket material. Then use a 50% Crush gasket that you can probably buy at any auto parts store and make sure you tighten the bolts to the Specified Torque Values for the manifold. They should still work ok. If you dont want to grind them then Sand Blast them and then paint them with a high temp paint if you want to make them look better. Good Luck.
JRBECK64 |
Born Psycho
![]() Join Date: Feb 2001
send them to a machine shop and resurface them, clean the head real good and put them back on WITHOUT gaskets. been in the exhaust business over 26 years and thats the way we always do them. as long as you torque them properly they will never leak unless the head surface is damaged.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Old member
Get a stiff wire brush on a grinder and take the old gasket off and see how they look then!
I have never used the gaskets on mine. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
