Old 08-01-2011, 11:03 AM   #1
Gene
Gene's Avatar
Proportioning valve, where to buy?
My bro in law thinks my brake problem lies with a faulty proportioning valve, so where in the heck can I get a new one? I have searched all the major parts stores and all they carry are aftermarket ones? Mine is a stock valve from a 1971 w/power brakes.
Gene is offline   Reply With Quote
Old 08-01-2011, 11:07 AM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Proportioning valve, where to buy?
ECE
aftermarkets lots cheaper though im running a brass disc/drum one from speedway
John
1999 Toyota Tacoma 4x4
Old 08-01-2011, 11:18 AM   #3
Gene
Gene's Avatar
Originally Posted by oldblue1968chevy View Post
ECE
Will they bolt up and work with stock lines?
Old 08-01-2011, 12:00 PM   #4
oldblue1968chevy
I believe so.
I redid all of mine...PM lolife99 he will know
John
Old 08-01-2011, 01:00 PM   #5
Eddie H.
Eddie H.'s Avatar
I bought an OEM replacement valve from Early Classic enterprises. It fits and works perfectly http://www.earlyclassic.com/catalog.aspx
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 08-01-2011, 02:04 PM   #6
bigsnookmaster
bigsnookmaster's Avatar
ECE is the best!
bigsnookmaster is offline   Reply With Quote
Old 08-01-2011, 02:05 PM   #7
Gene
Gene's Avatar
Thanks, if I cant locate one locally I will definitely use them.
Old 08-01-2011, 02:54 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
ECE.
They have a stock appearing Prop. valve.
Keith
Convert to disc brakes.
Old 08-01-2011, 03:08 PM   #9
barry h.
barry h.'s Avatar
i got mine from performance online at a good price.
barry h. is offline   Reply With Quote
Old 08-01-2011, 03:31 PM   #10
Gene
Gene's Avatar
I just need to rule everything else out before I try a new prop. valve, I have installed a new master cylinder, all new brake lines front to back, new brake pads, bled lines repeatedly, have went through 3 large brake fluid bottles. I have a firm pedal and the truck will stop, but I cannot make the brakes lock up even on grass or gravel? Any ideas?
Old 08-01-2011, 05:19 PM   #11
bruin_d
bruin_d's Avatar
What about the rubber one in the back that tees off to both of the rear brakes? Did you change that one? I've had one of those clog before.
bruin_d is offline   Reply With Quote
Old 08-01-2011, 05:24 PM   #12
Gene
Gene's Avatar
Yep, I have replaced all the lines on the truck including that one with brand new lines. I had better brakes on this truck before I rebuilt it when I only had front brakes. I did some more looking and i'm thinking the booster may have a leak now, I can pull the vacuum hose while it's running and the engine sounds the same, but if I block off the hose the engine rpm's drop. I'm going to change the booster next and go from there.
Old 08-01-2011, 05:33 PM   #13
bruin_d
bruin_d's Avatar
I was going to suggest the booster first but you said the pedal was firm so i didn't say anything. Sounds like you may have a leak. I would probably go for the booster next before the prop valve. If the rubber ones weren't clogged, the prop valve probably isn't clogged. Just my $.02.
Old 08-01-2011, 06:23 PM   #14
Gene
Gene's Avatar
Yep, its firm. Firm to the point I have to come off the seat to make it stop.
Old 08-01-2011, 06:28 PM   #15
bruin_d
bruin_d's Avatar
What about the wheel cylinders in the back? Have you verified they move? I've had them freeze on me before. Just trying to throw options out there.
Old 08-01-2011, 06:44 PM   #16
cpisani70@aol.com
cpisani70@aol.com's Avatar
So I too am having trouble with my brakes in my 71 only my problem is that I have mostly back brakes. If I try a quick stop the backs instantly lock up the nose doesn't even drop a little. Very tough to drive in the rain, I was thinking it was the prop. valve . Any help would be great.
cpisani70@aol.com is offline   Reply With Quote
Old 08-01-2011, 08:37 PM   #17
Gene
Gene's Avatar
Yeah, I jacked the back up and spun them while a friend hit the brakes. They are working. I even manually adjusted them until they were grabbing then backed them off just until the wheel would spin. I'm at a loss guys, I replaced the valve that goes to the brake booster and it seemed to help but it still seems like the power in my power brakes is lacking. I've got alot of vacuum when I cover the hose with my finger, i'm pretty sure my booster is shot. I'm going to find another booster that I know to be working and try it.
