Old 08-01-2011, 02:32 PM   #1
HSkinner
700r4 wiring? (I know, I know.....)
This question has been asked so many times in so many different ways but all i want to do is lock up 4th the simplest way possible. Do I just run power to the A post and ground the other 2 or? Do I need an inline toggle switch?
HSkinner is offline   Reply With Quote
Old 08-01-2011, 02:45 PM   #2
Indyuke
Re: 700r4 wiring? (I know, I know.....)
No inline toggle switch. Your circuit should look something like this:
wire from acc position > 4th gear pressure switch > ground.
The torque converter will only lock up when the trans is in OD, and as soon as it drops out of OD it will unlock.
Indyuke is offline   Reply With Quote
