Old 08-01-2011, 06:36 PM   #1
txhoss
i need some help
i have always owned chevys between 88-98 and they have been 5 speed but i thought that i would buy a 95 z71 but the truck wont go into 3rd gear so wat i need help with does anyone know what it could b and how do i find out what kind of trans it is thanks
txhoss is offline   Reply With Quote
Old 08-04-2011, 12:47 PM   #2
scotts62
One day...
scotts62's Avatar
Re: i need some help
ttt
Scott
93 crew cab build
Project 62
Old 08-04-2011, 06:51 PM   #3
TURFKING
check the VIN and plug in a scanner.
TURFKING is offline   Reply With Quote
Old 08-04-2011, 07:38 PM   #4
txhoss
wat am i looking for on the vin to tell me
Old 08-04-2011, 08:32 PM   #5
txhoss
Originally Posted by scotts62 View Post
ttt
wat
Old 08-05-2011, 05:18 AM   #6
dishow
dishow's Avatar
If its auto then its a 4l60e.
90 Chevy 454 ss
Old 08-05-2011, 06:07 PM   #7
TURFKING
'95 should be a 4l60e,if it's the original tranny. Scanner may or may not diagnose a problem with the shifting. Your VIN ,compnine.com, will give you detailed info on your truck. Interior,paint codes, engine, tranny, gear ratio's and even how many of that particular build were built. RESEARCH, there is a lot of info on the net. You just have to dig and skulk around the net.
Old 08-05-2011, 06:37 PM   #8
scotts62
One day...
scotts62's Avatar
Originally Posted by txhoss View Post
wat
To The Top
Giving you a bump
Scott
93 crew cab build
Project 62
Old 08-06-2011, 01:13 AM   #9
txhoss
well im going to look into it tomorrow i went and picked the truck up today and i was driving it 1st and 2nd gear shifted fine but wen it shifts to 3rd u can fill it pull a little then it stops and acts like u put it in Neutral if u try to stay low rmp it will stay in 3rd and pull a little but if u hammer it it wont do anythinghttp://67-72chevytrucks.com/vboard/i...s/confused.gif
Old 08-06-2011, 01:23 AM   #10
BMERDOC
BMERDOC's Avatar
Not much on the 480LE but can you manually shift through all the gears?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-06-2011, 10:37 AM   #11
txhoss
even if u shift the gears it still wont do anything in 3rd gear it pulls a little then stops
Old 08-06-2011, 03:25 PM   #12
txhoss
Angry Re: i need some help
well i just called a tranny shop and he said that the clutch pacs r out and that he would rebuild it for 1200 - 1900 depends what he finds out and that is him pull it and put it
Old 08-06-2011, 05:36 PM   #13
TURFKING
Could be the shift solenoids or it could be something as simple as changing the tranny fluid. Scan that rascal! Tranny shop is next stop.
Old 08-06-2011, 06:28 PM   #14
speedygonzales
speedygonzales's Avatar
Better take vasoline to that shop if you go back
$1929 for a replacement unit from Hughes. Tell him to stick it.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 08-06-2011, 06:51 PM   #15
SiCk_DiAbLo
SiCk_DiAbLo's Avatar
Bad Speed Sensor??
1993 Chevy Silverado.
1984 Chevy Z28.
1972 Chevy Custom 10.
1965 Custom 10..FOR SALE
SiCk_DiAbLo is offline   Reply With Quote
Old 08-07-2011, 03:27 PM   #16
txhoss
were is the shift solenoids at u think if u replace the fluid and filter would help and if i take it to any shop that has a scanner they could do it
Old 08-08-2011, 07:14 PM   #17
TURFKING
You need to do some research online. gmtruckhq.com The shift solenoids are on bottom on tranny but you have to pull the pan and really know what you are looking for before you start fiddling around with things. There are manuals for the 4l60e but they are shop repair manuals and not knowing what you are doing can cause you a lot of grief!!!!!
