Old 08-01-2011, 09:00 PM   #1
BMERDOC
BMERDOC's Avatar
Speedo Doesn't Work
Did my due dilegence and searched the site but didn't find anything. What are the top things that make a speedo malfunction in these trucks? It doesnt work at all and everything is hooked up corectly.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-01-2011, 09:13 PM   #2
70cst
70cst's Avatar
Re: Speedo Doesn't Work
ttt
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-01-2011, 09:36 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
If you can remove the cluster and check the back and see if it freely moves on the gauge to rule out the gauge being stripped...my first guess would be the speedo cable...I have several that I've thrown out of parts lots I've gotten because they were either kinked or had melted to headers/exhaust manifolds and wouldn't function...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-01-2011, 09:41 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
unhook it from the trans and see if you can spin it by hand or drill to work. if so it's probably the drive or driven gear in the trans (little plastic gears) mine don't work because of the driven gear is broke just ain't got to it yet
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
