Old 08-01-2011, 09:46 PM   #1
cardreams
help with shocks please
hey guys need some help in chocieing shock for my 68 its got a 2 1/2 drop spring and a 2 drop coil in the front and like 5 drop coil in the back but it looks like a stock shock any suggestions would be great was thinking a QA1 coil overs on the back and just QA1 shocks on the front need a better ride and they would be fully adjustable has anyone have them on there truck
Thanks Andrew
cardreams is offline   Reply With Quote
Old 08-03-2011, 11:39 AM   #2
cardreams
Re: help with shocks please
bump
Old 08-04-2011, 02:40 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm no help with the QA1's.
You might search in the Suspension Marketplace.
ttt for you.
Keith
Convert to disc brakes.
Old 08-04-2011, 04:29 PM   #4
robnolimit
robnolimit's Avatar
QA-1's website will have all of the shock lengths listed. You can look up or search a style of shock, with the correct mounts on each end, then look up the lengths available and see what you can use. As far as coil-overs on the rear, are you planning on removing the drop coil thats in place now? To get 5" of rear drop, I usually recomend a 2" block, and a 3" spring. The shorter the spring, the worse the ride. Also, as the shock gets shorter, thing go from bad to worse. Shock relocators are in need here, we have some new design that work very well. If your going to use a coil-over, try a 200lb spring, I'd recomend a 5" stroke shock, like the QA-1 #5855p. Hope that helps.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
