Old 08-01-2011, 10:12 PM   #1
windmill
windmill's Avatar
pics needed, 72 chevy coil to leaf springs
i'm needing some pics to see where to drill for hole to do the swap from coils to leafs.... send to turbomonk@hotmail.com or post some..... need soon as posible.... thanks monk
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline   Reply With Quote
Old 08-04-2011, 02:43 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: pics needed, 72 chevy coil to leaf springs
Anyone?
Keith
Convert to disc brakes.
Old 08-04-2011, 04:06 PM   #3
SCOTI
SCOTI's Avatar
Unfortunately, it's kind of a vague question so there might not be much response. You should be able to tell where (if) any holes needs to be drilled once you start installing the coil specific suspension brackets.
Check w/board member Gringoloco. He can prob shed some light on the swap.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-05-2011, 07:09 AM   #4
windmill
windmill's Avatar
its not a hard ? ,,,,,just need some close up pics,,, anyways done got them drilled and mounted the 4 perches so far,, just now need where to mount the shock brackets,,,, hoping to change everything sat and sunday.... mounted my tralior hitch last night going to pull the race car to the track tonight.... like to see what diff it makes between the two suspisions... i'm going to post some later maybe this could help a fellow member out sometime....
72 swb pickup
1967 chevelle ss
Old 08-05-2011, 08:51 AM   #5
SCOTI
SCOTI's Avatar
Again.... Vague, not hard (there's a difference). I was trying to pin down specifics of what pics you needed most.
As for a difference between the 2 suspensions on the same truck? The coils (especially w/air bags swapped in place) will offer better ride quality. I used 2 swb trucks (1 w/leafs suspension; the other w/coils) to tow the same 18ft car hauler. The coil set-up rode better loaded & un-loaded.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-05-2011, 11:37 AM   #6
windmill
windmill's Avatar
my dad had bought a new 72 lwb truck when i was younger,,, i did pull a 67 chevelle with it when i raced,, it done a good job but did sway somewhat,,, now i have a swb 72 thats been lowered 2 and 4,,,, i think i can swap to leafs cheaper than buying bags and all,,,,, sell my rear springs and buy lower shackles
and take a spring or 2 out and still ride as good as the coils and not have the sway,,,, my trailors right now is 18 ft but going to extend to 23ft too haul a car and golf cart so it will be a good heavy load.... but i will not always be useing the truck to haul i do have an 05 crew cab chevy truck i do use until now,, it sure does have alot of room inside it... hey thanks tho....
72 swb pickup
1967 chevelle ss
Old 08-05-2011, 01:34 PM   #7
LONGHAIR
All of this work for a 1/2 ton short wheel-base truck? Pulling a 23ft trailer with a racecar and a golf cart? ...and you are thinking about removing leaves?
Too much load, not enough truck......and waaay not enough brakes.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-08-2011, 05:49 PM   #8
windmill
windmill's Avatar
here's my truck and race car.... before the leaf spring change.
72 swb pickup
1967 chevelle ss
Old 08-08-2011, 09:24 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- both my trucks were leaf and converted to coil... I could prolly get some good pics of where the holes are
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-08-2011, 09:32 PM   #10
windmill
windmill's Avatar
send me some of where to mount the top shock mounts ,,,, send to turbomonk@hotmail.com
done mounted the leafs and rear end so far, waiting on a rear brake line to bleed the fluild... prob have to cut the top frame support to mount the top shock brackets, but not a big deal... i have plasma cutter...
cant wait to haul with it!!!!!!!!!!!!!
72 swb pickup
1967 chevelle ss
Old 08-08-2011, 11:29 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Hey windmill. How about sharing pics for those that might need them in the future?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-09-2011, 12:37 AM   #12
windmill
windmill's Avatar
i'm going to as soon as i get everything on,,,,,maybe it will help the next person out...
so far it seems like it has more movement in the rear suspension now than it did before,, but i dont have the shocks and bed put back on yet...
72 swb pickup
1967 chevelle ss
Old 08-09-2011, 10:00 PM   #13
windmill
windmill's Avatar
ok i changed the setup now,,, raised the truck back to stock height,,, so now my drive shaft wont work to short....
will the change from coils to leafs make that differance?
72 swb pickup
1967 chevelle ss
