Old 08-01-2011, 11:40 PM   #1
67 swb
Disc brakes
Does any one know if the factory front disc brakes from a 67 1/2 ton 6 lug fit on a 66 1/2 ton 6lug. Want to put disc on the 66. found a 67 with disc.
67 swb is offline   Reply With Quote
Old 08-02-2011, 05:29 AM   #2
cdowns
cdowns's Avatar
Re: Disc brakes
not factory in that 67 they aftermarket
read up on board rules about double posting
Old 08-02-2011, 07:47 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc brakes
GM didn't put disc brakes on these trucks until the 1971 model year.
IF you can get EVERYTHING off this '67 truck,... you can swap it over to your '66.
You will need:
-A-arms
-spindles assemblies
-All of the steering
-Master cylinder
The steel brake lines will be different also.
Please explain what you plan to do.
It won't be a bolt in swap.
Keith
Convert to disc brakes.
