Old 08-02-2011, 11:40 AM   #1
blackdawg
Blackdawg
small crack trans bell housing
bolting up the trans to the engine there is a small crack on the bell housing.see attached pic.also the torque covertor is in made sure its seated in double hump.I' m little vague in this area is there bolts from the torque converter to the fly wheel.
blackdawg is offline   Reply With Quote
Old 08-02-2011, 02:27 PM   #2
Greg63
Enjoy your truck
Greg63's Avatar
Re: small crack trans bell housing
What kind of transmission is that?
My aluminum Muncie M21 had that happen. The crack was a complete break, and I ended up pulling the transmission and getting the tab welded back on.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 08-02-2011, 03:02 PM   #3
blackdawg
Blackdawg
just a regular chevy turbo 400
Old 08-02-2011, 03:33 PM   #4
losthope
losthope's Avatar
yes you need bolts to the flywheel .....i was missing the ones when i put mine in, i just went to hardware store and got some short grade 8 bolts, there wasnt enough room to put a lockwasher on the bolts under the nuts cuz of the small dimples in torque converter where the tabs are, so i used some nylon lock nuts and a little lock-tight, dont worry the torque converter will need to slide back out of the trans a little to bolt up to flywheel. You might get away with running it with that crack since there should be 5 other bolts holding the trans to motor but would be ideal to have it fixed!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 08-02-2011, 08:50 PM   #5
blackdawg
Blackdawg
thanks, thats what i thought it needed to be bolted to flywheel.its been a long time doing a major project.its the little things you forget.For now the trans bolts up fine, i will keep a eye on the crack.if it becomes a problem i will get it welded.
