Old 04-06-2003, 11:06 PM   #1
Mike C
Mike C's Avatar
Engine dolly pics
Somebody wanted to see some pics of my engine dolly I had built. I have 4 of them, all with small blocks. Haven't tried a bigblock on it, but I would use thicker steel. It is 2" square tube, 14ga with 1/8" x 1 1/2" angle iron. The ends of the tubing is filled with plastic post caps. I got them at a close-out at Home Depot. 4 for 1c. I bought like 50c worth!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-07-2003, 02:04 AM   #2
67cst
i love summertime
67cst's Avatar
here is my engine dolly, doesnt roll around too much
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 04-07-2003, 08:40 AM   #3
Randy70C-10
Randy70C-10's Avatar
Nice dolly mike, gives me an idea. What kind of engine is that? Looks sorta like my ZZ3.
Randy70C-10 is offline   Reply With Quote
Old 04-07-2003, 10:55 AM   #4
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
67cst, thats what you call the junkyard special eh? At least the engine looks comfy in its nice tire pillow, better than having bolts driven into to you.
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 04-07-2003, 12:47 PM   #5
Blue Beard
Blue Beard's Avatar
Mike
That's a different stand but looks good.
67cst
maybe if you put the wheels back in those tires they would roll around.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-07-2003, 01:00 PM   #6
junkyardjohn
junkyardjohn's Avatar
Thumbs up
MIKE -- YOU'VE INSPIRED ME TO STOP WHAT I'M DOING & GO GET ENOUGH STEEL TO BUILD A COUPLE. THANKS
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 04-07-2003, 04:50 PM   #7
Mike C
Mike C's Avatar
Glad I could help. I built the work bench in my clean room just so you could store extra engines underneath it. Actually could use a few more! www.northerntools.com has a really nice steel wheel caster rated at 1000#, $3.49 for rigid and $3.99 for swivel. 4 swivels would make it easier to store under the bench, but the two rigid make it a LOT easier to steer across the shop...
The motor is a 96 Camaro SS LT1 with CNC heads ported heads and a crane cam. That is the GM Performance parts carbed LT1 intake. I'll get the car running with the carb, then convert to FI when I can afford to do either Commander 950 or DFI Gen VII. The shorty headers are only for show. They don't clear the angle plugs. I have another LT1, and iron headed straight plug motor that will get the carbed intake and shortys and put in my Datsun with a WC T5.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-07-2003, 05:09 PM   #8
Blue Beard
Blue Beard's Avatar
Nice looking items, keep us posted on your ride.............
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 04-07-2003, 07:30 PM   #9
Chevy67Tk
Chevy67Tk's Avatar
Cool stand do you have any rough dimensions on it. I need to build one as my project is about to get put on hold for a while.
Chevy67Tk is offline   Reply With Quote
Old 04-08-2003, 10:50 AM   #10
Mike C
Mike C's Avatar
I'll get some rough measurements for you. The uprights and the braces are bolted to tabs welded to the base frame. This gives some "tweaking" adjustment to the whole assmebly for fitting to the back of the block.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-08-2003, 10:59 AM   #11
bpmcgee
bpmcgee's Avatar
Chris,
What kind of headers are those?
Brian
Oh, and nice stand too!
B
bpmcgee is offline   Reply With Quote
Old 04-08-2003, 10:59 AM   #12
bpmcgee
bpmcgee's Avatar
Duh,
I'm sorry, I mean MIKE what kind of headers?
Sorry, brain fart.
Brian
Old 04-08-2003, 03:15 PM   #13
Mike C
Mike C's Avatar
The headers are a set of blockhuggers that I bought used. Not sure of the manufacturere, but they are 1 5/8" with 2 1/2" collector. Pretty standard stuff.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-08-2003, 03:54 PM   #14
bpmcgee
bpmcgee's Avatar
Mike,
Thanks. I'm looking for a set of short-pipe headers that I can use with a planned Holley TBI system. They say in their literature that long-pipe headers wouldn't let the o2 sensor get hot enough.
Do you anticipate a problem with changing plugs?
Brian
Old 04-09-2003, 11:08 PM   #15
Mike C
Mike C's Avatar
Plugs should be easy enough on these shorty's. Check out Patriot shorty's. I think they are owned by Proform, but they have round or D ports, they use cone/flange instead of gaskets at the collectors and they have straight or angle plug. If you are in the 350hp or so range (net) then the 1 5/8 2 1/2" collector should be fine. Just mount the 02 bung in the collector just past the header.
44 Willys MB
52 M38A1
64 Corvette Coupe
