Helper bag kit
Hey guys, need a little help. I'm looking at putting in some help bags just so I have extra support when pulling our boat. I've seen a number of posts with guys doing the same.
I know they don't make a specific kit for the 72, but what kits are you using? I contacted Jegs and they said they don't have a kit. If you have a specific part number, that would be greatly appreciated. THANKS! |
#2 | |
Re: Helper bag kit
69 Chevy 4x4 383 Power ![]() |
What?
Re: Helper bag kit
I have a set that I took out of a 67 leaf sprung burb.
Don't know who made them, but they don't look at old. So, they are out there.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Re: Helper bag kit
Trailing arms. No leafs.
Re: Helper bag kit
Did you look at the Air Lift 1000 in the link I posted above. It fits open coils and is only $90
Re: Helper bag kit
Just swap bags in place for the rear coils. Leave them @ 30-40psi unloaded & add some air via a simple schrader valve set-up when you plan to load it down. You would be purchasing 2 bags regardless right?
Re: Helper bag kit
If you go this route you may want to consider adding a rear anti sway bar.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
Re: Helper bag kit
Not really a 'must have' but sure won't hurt. The bags won't be any worse than coils; they'll just allow for height/capacity adjustability where coils won't.
Re: Helper bag kit
Actually, we like the truck just the way it is. If we decide to do a frame off restore or go more custom, then I would concider just going bags in all corners.
But really, we're just looking for something to help make it a little safer when going down the road to the boat launch. Plus the helper bags seem pretty easy to install and just use when needed. Thanks for the link. |
#10 | |
Re: Helper bag kit
'Helper' bags for coil applications go inside of the coils meaning you would remove the coils for the installation unless your going to do some sort of 'custom' set-up. If you're removing the coils anyway, just bolting in an air-spring that replaces the coil is easier. Regardless of which way you go, you still have to route air to the bag to be functional so that's a wash.
Re: Helper bag kit
Someone on here is using these. I've been saving the link for myself. http://www.performanceonline.com/196...DE-ASSIST-KIT/
Re: Helper bag kit
I've seen them also. If I was going to spend the $250, I would just go with swapping out the coils for bags.
Like I said, we like the stance the way it is. Just looking for something to stiffen up the back end. At $85, the helper bags seem the best route. |
#13 |
Re: Helper bag kit
Link for what you intend to use?
#14 |
Re: Helper bag kit
I think he is looking at the link in my first post for the Air Lift 1000
#15 |
Re: Helper bag kit
That's correct...
#16 |
Shortbed club member
Re: Helper bag kit
Someone told me these would work, so I saved this link.
http://www.sdtrucksprings.com/index....oducts_id=6894
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
#17 |
Re: Helper bag kit
Unfortunately the kit from Auto anything is only for the 1 ton. I've seen guys with kits......anyone else know???
#18 |
Re: Helper bag kit
Description from the AirLift 1000 front kit posted:
•The perfect helping-hand for your open coil springs, giving you up to 1,000 lbs of leveling capacity •Fine-tune the level of dampening for the right mix of load support and ride quality •Tough polyurethane construction is custom-molded to fit your springs •Made just for open coil spring suspensions The text states these are for open coils & that they can be used front & rear. But, the rear coils in this application are not 'open'; they're pigtailed (closed) on both ends. Do they make something similar that works w/the closed type coils?
#19 |
Old member
I love mine.
I ran the air lines back to the bumper and made them the tag bolts! Oh man it made a differance in the ride. No more bouncing when I go over small humps in the road. Man I need to move those shock's one of these days.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#20 |
Re: Helper bag kit
Yours are the pictures I've seen. Do you remember what kit you bought?
#21 |
Old member
PM sent!
