Old 08-02-2011, 02:30 PM   #1
darkone
Help me ID my Rear-end.... for drum brake rebuild
hey all, im flipping thru my lmc truck mag, but the rear end id in here pretty much only seems to id DANA rear ends. i need to order new drum hardware, but i of course have to know what im running to do so. any help would be appreciated. thanks!
darkone is offline   Reply With Quote
Old 08-02-2011, 03:29 PM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: Help me ID my Rear-end.... for drum brake rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=477294
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 08-02-2011, 03:29 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
You don't give a guy much info to go by but I'm guessing you have a 3/4 or 1 ton. If so the 3/4 would be the Eaton Corporate or HO52 rear axle. If it is a 1 ton it would have the HO72. Good luck finding parts for it. You might be able to find some of the smaller stuff but if you need drums you will have to find some good used ones...
LockDoc
Leon
Old 08-02-2011, 04:17 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Look on the right axle tube, on the top of it, and you should find a group of letters and/or numbers.
Also, what does your SPID (if it is still in the truck) say?
I only count 10 bolts. According to some of my reference materials....it's quite possible that it is just that...a 10-bolt. Since I see coil springs, you don't have a 1-ton.
Member Nr. 2770
Old 08-02-2011, 04:21 PM   #5
ed2552
ed2552's Avatar
Looks like an HO52 in a Chevy C20 to me. Can't be a 1 ton since it has coils and it's not a Dana or a 12 bolt.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 08-02-2011, 05:34 PM   #6
ERASER5
ERASER5's Avatar
BUT disc conversions are availabe.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-02-2011, 10:34 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
its not a ten bolt, it is the corperate/eaton HO52. Most parts stores list dana or non dana.
Old 08-03-2011, 07:09 PM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I got new drums for my 71 C20 with the same rear from either Autozone or Advance auto for about $108 each a few years ago.
They aren't available for the 1 tons that I could find, I looked for my wrecker project.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-03-2011, 07:35 PM   #9
vectorit
What?
vectorit's Avatar
Being that it is a 2wd, you should be able to source all drum brake hardware from any good parts house.
I got spring kits, shoes, and wheel cylinders from my local Napa store.
Drums are another story, and may take time to find.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-04-2011, 01:08 PM   #10
ed2552
ed2552's Avatar
If your drums are in good shape you can have them turned. My local NAPA turned my fronts for $10 each.
