exhaust manifold bolt replacing?
I have some bolts on my manifold that bolts to my exhaust that are rusted out and I'm wondering how to replace them. I've tried unscrewing them and have had little luck. Any help would be great. The manifolds are already off by the way
1969 Chevy c20(Miss Hackjob) |
![]() Join Date: Jan 2001
Re: exhaust manifold bolt replacing?
That's a tough one. As far as chemicals go, you could try PB Blaster. I think it's the best for loosening rusted parts. You could try heating the area around the bolts and cooling the bolts too.
i've always heated to bright cherryred to get them to turn
I've shot it with pb blaster already
![]() ![]() Posted via Mobile Device
X2. Get them hot and turn the bolt a little. Repeat and repeat until it comes loose. It takes patience.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Try working it in both directions also (tightening and loosening). Kroil it up, and lightly try to work it....heat and freeze might work...but just be patient.
Also try lightly tapping the end of the bolt to shake things up. It may take a few days. Good luck. |
So I've been told.....when you heat them up, but some beeswax on the hot part. Beeswax is supposed to have smaller molacules that will get into tighter areas better than PB/Kroil/WD40.
I've never done it, but some old time tractor restorers swear by it. HTH..good luck...don t. .... |
Heat cherry red as the others have said. The wax thing sounds interesting!
'96 GMC Suburban 6.5t '99 F**d Windstar '07 SON '09 DAUGHTER XOXOXO Wife |
I don't know if you have this guy but its what I have used in the past. I have also tryed the candle wax trick with a little luck most of the time you just have to heat them up.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
![]() Join Date: Jul 2010
In our shop we don't think twice. We grab a torch with a rose bud and get them cherry hot like the guys above said. Works great!
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
I don't have a cutting torch lol I might take them to a shop
