75 K20 Crew Cab Project
I just found this sight and wanted to do a build thread. This build will be slow, due to full time student.
This will be my DD, but for now I have a 92 D250 I did a SAS and ALOT of work to it. ![]() ![]() I got this in trade for a set of wheels. It needed ALL new glass, and basically all body panels. I slowly started cleaning it up. ![]() ![]() ![]() ![]() ![]() ![]() |
Re: 75 K20 Crew Cab Project
The truck had ZERO rust and was FREE! So I started going to work. Mind you it had a running 350 crate motor with under 5k on it, TH350/203. Flat top 44, 14 bolt FF with 410s. Had a NEW 6" lift.
Interior was ****, and the PO cut the last 10" off the rear of the frame ![]() ![]() ![]() Couple more pics: 40's ![]() Took it for a drive: ![]() Interior gone and Herc-u-Lined. ![]() ![]() Did a little clean up- ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Crappy silver paint job inside: ![]() ![]() |
Did a little interior, got all this free from a friend-
![]() ![]() FULL RESTO! All new painted doors and cab off resto. 5.9 Cummins with a NV4500 and Ford 205. I have a 78 HP60 and 14 Bolt with 410s and Lockers. H2 wheels with 37" Falken AT's. |
Waiting to see the transformation!
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
![]() Join Date: Oct 2006
Thats gonna be one bad ass truck.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Parts list as planned-
4" Soft Rides up Front 2" Soft Rides out back ORD Shackles and greesable bolts Avi Eng. Crossmember 94-98 12v P-Pump NV4500 Ford 205 Full GM Interior from Never truck (same as my dodge has) Lots of other things to add as i go. |
I love the 73-87 Chevys.......
This was my old truck I had in high school. 350/350/203 44/14 Lockers Lots of stuff CLEAN. (Bumpers off it going on CC). ![]() I built a crawler and parted it out. WORSE IDEA EVER! ![]() ![]() |
Like it!!!!!
Eric "Target" Sherwood Professional Bullfighter For Hire God Bless and Gods Speed! TheCowBoyProtectionUnit@yahoo.com http://www.facebook.com/pages/Eric-T...59496227444241 |
Thats about what i want to do with my 91 k30 is full frame off full paint and interior cummins havent decided on a tranny yet but looking into the 4500 also and 205. Im gonna use mine for a daily driver also. picked it up from the side of the road had blown tranny guy sold it to me for 500 then i pulled the 6.2 and sold it for 600 and used the axles on my k10. wantin to make it my hauler. also was thinking about putting newer chevy 2500-3500 duramax seats in it they are like recliners! lol havnt done the measuring yet but hopefully i can make that work!
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT" 2007 cbr 1000rr ![]() |
#13 |
Out of all my trucks I love that crew cab the most.........
![]() Thats my other. |
#14 |
You got all kinds of toys! but that cummins is sweet! Cant wait to see the Chev with a cummins, perfect match
#15 |
The Cross member I will be buying soon. Might of traded some 37" H1 tires and Wheels for a 92 auto.
http://www.avalancheengineering.com/new_products.html The swap begins quick. Just need to sell my 454/400/203 combo to get a NV4500. Using my 79 HP60, so I can mate my FORD 205 to the NV4500. |
#16 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
I was never able to get ahold of them. Heard they shut down.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#17 |
#18 |
#19 |
Looks good
I'm not sure you need that cross member. I would box in the front half of the frame and use the stock engine mounts from 94 to 02 dodge for the frame mounts if you can't get a downer frame piece you could use 3/16 plate for engine mount and some 2x3 x1/8 tubing for your cross member just some ideas also run a search for cummins swap there's other guys that have done the same thing not to get off the subject i did a lot of wheelin in the wash near you from mcbean to Indian duns long ago 1979 thru 1986 then they ran us out here some pics of my old trucks i built i sold them all good luck JM Last edited by junkmen; 08-06-2011 at 02:32 AM. |
#20 |
Those guys at Autoworld have some nice stuff too. I also really like Tennessee Diesel Conversions. He is Crewcab59 on this and alot of other forums.
#21 |
I was thinking about the drop is crossmember because they put the motor right in the perfectly. Plus I dont have a welder at my other house.
#22 |
Will be putting my 78 hp60 with chevy outers in this truck.
410s front and back with detroits. I will be mating the 4500 to my ford 205 ![]() ![]() |
#23 |
And ALOT of trading parts this and that got me to were I am today:
Interior I got was used, front seat needs to be redone, and will be getting new carpet soon. The front clip was a 84, I have my 78 Front clip I will be running instead. I like the old circle head lights better anyways..... ![]() NEW 4" Skyjacker Soft rides. ![]() My new D60, 456s, high steer (dont know if I am going to use this). DRW for use with my H1 wheels and 37" BFGs. ![]() All the heater and AC stuff was JUNK, I have to get all new stuff. ![]() ![]() My built 454, LOTS O Powa. Ive been thinking about running a LS motor. I will try to trade for one. ![]() NV4500 6.32 Granny low. I got this is trade, I also got a 32 spline 205 in trade, not I just need to convert it to 4wd. ![]() |
#24 |
Have this built 454...... I put it up for sale ONLY because I met someone who did a 5.3L swap and he REALLY like it alot. I like the EFI setup and with the NV4500 and 456 gears I should be great with 37s.
Some pics, new poly body mounts, found some SRW hubs, also am searching for a short bed (but a flat bed, 6 or 7' SRW)... Plus I found my NP205, 32spline. GOt it in trade for some seat belts I was NOT using. I am going to AA for my conversion. ![]() ![]() ![]() ![]() This is a pic of H2 wheels with DRW hubs. ![]() |
#25 |
Truck Nut
![]() Join Date: Jun 2007
Sweet build. Trade, trade, trade!!!! Trading is the best. My buddy has -$200 in his 85" swb roller. All through trades. Great pics
Tony Kee Texas Square Bodies |
