Old 08-03-2011, 09:33 AM   #1
Ridnhi
Ridnhi's Avatar
Will truck bed fix blazer bed??
I was wondering if anyone has used a truck bed to fix blazer bed around the wheel wells? I also have to fix the back 6 inches of the bed about 12 inches wide on each side. Has anyone bought a patch and had good luck? Or should I find an OEM bed floor. Thanks for help
1972 K5 Auto 4x4 factory air
2007 Silverado extended cab Z71
Ridnhi is offline   Reply With Quote
Old 08-03-2011, 11:55 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Will truck bed fix blazer bed??
VTBlazer did a build thread on using shortbed bedsides to replace blazer bedsides. http://67-72chevytrucks.com/vboard/s...d.php?t=360248
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-03-2011, 12:54 PM   #3
1972k5blazer
I got a sweet tub i can sell you !
1972k5blazer is offline   Reply With Quote
Old 08-03-2011, 04:20 PM   #4
Bentblazer
Bentblazer's Avatar
I used a LWB bed floor as a replacement for my blazer floor, you have to cut the front and back to fit. Wheel wells and mounting areas all matched. ( Floor only)
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 08-03-2011, 10:52 PM   #5
Ridnhi
Ridnhi's Avatar
Thanks for info. I guess I needed to be more specific, but I meant the the wheel wells on the floor.
Old 08-03-2011, 11:11 PM   #6
Ridnhi
Ridnhi's Avatar
Josh- I would love that tub but I should be able to fix this one.
Brentblazer- thanks, did you repair the tail end of your bed with the truck bed?
Old 08-03-2011, 11:22 PM   #7
jaros44sr
jaros44sr's Avatar
That is very interesting, wouldn't have guessed that
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-04-2011, 08:07 AM   #8
Bentblazer
Bentblazer's Avatar
I used a complete LWB bed floor, had to cut the front and rear along with the notches near tailgate under bedside. All bedside holes and wheel house holes matched. Also used the rear crossmember but had to redu the frame mounts on all of the cross sills, (truck cross sills are not recessed like blazer mounts) The bed bolts in are relocated from the truck location to the half moon area in bed, but all matched really well. I measured EVERY LOCATION ABOUT 20 TIMES AND CUT ONCE! It was very time consuming but all worked. I was able to reuse a original bedside and a repopped bedside, only 1 hole didnot match and it was near the rear of the repopped side in the floor. Hope this helps.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 08-05-2011, 09:25 AM   #9
69-72
69-72's Avatar
I did this too, I used the first few inches of the front section of the Jimmy bed and just took a section out of the rear part and welded it back together. And if its a 72 the relief in the rear cross member will need to be created.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 08-05-2011, 04:09 PM   #10
Bentblazer
Bentblazer's Avatar
We must have been thinking along the same line, I also used the front 6" to give it the factory look.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 04-04-2016, 10:40 PM   #11
jakesblazer
Thumbs up Re: Will truck bed fix blazer bed??
Hey 69-72. Great idea using a donor front out back!! I am going to try this !
jakesblazer is offline   Reply With Quote
