Old 08-03-2011, 09:35 AM   #1
slowboy
slowboy's Avatar
hard start to start
'72 GMC P/U with 350 A/T Headers and Qudrajet 4bbl
Choke is working fine. But...I have to pump accelerator pedal 7-8 times in the morning, then it might start. If not, I pump it about 1 and a half times more then it starts.
The original 'cold start' instructions on the back of driver's side sunvisor says to press pedal all the way to the floor, and slowly release. Then start engine. If engine does not start, repeat procedure.
How do I get this to work right? I don't remember truck ever starting that easy, but would be great if it would.
Thanks,
Keith
slowboy is offline   Reply With Quote
Old 08-03-2011, 07:17 PM   #2
MagmaJct
MagmaJct's Avatar
Re: hard start to start
I have to ask, how do you know the choke is working? Can you describe how your is working? Does it start to run, then die? Or does it not catch at all?
The choke is supposed to be almost completely closed when cranking, once the engine starts and vacuum is produce the "choke unloader" is supposed to open the choke a bit more to allow enough air for the fast idle to run.
Maybe the choke appears to be operating properly but is incorrectly adjusted?
MagmaJct is offline   Reply With Quote
Old 08-03-2011, 08:01 PM   #3
68gmsee
Active Member
68gmsee's Avatar
After you check the choke, you may have to also take the carb off and give a good cleaning, get a carb kit and replace the needle valve and base. It may be that the needle valve is gummed up and/or has debris allowing the gas to leak back out. The kit also has the accelerator pump and some other parts in it like ball bearings, gaskets, that you can replace also.
Another thing that can happen on these quadrajets is leaking jet plugs under the top half. In other words you have to remove the base to see the plugs. Check to see if they've been epoxied up to prevent leaking. If not, you will have to do it.
Caution: they're not the easiest things to work on, so if you're not experienced or this is a daily driver, I'd have someone else do it.
68gmsee is offline   Reply With Quote
Old 08-04-2011, 08:26 AM   #4
slowboy
slowboy's Avatar
I push the gas pedal 'once' and choke closes...but, I have to pump gas pedal 7-8 times before engine starts...when engine does start, choke opens about 1/8th of an inch or so and fast idle starts...as engine warms up, choke plate opens completely up...seems to me choke is doing what it is suppose to do...my problem is there is no gas pumping into carb from fuel line to start engine...I'm 54 yrs old, and all carbs I have ever seen, when you pump gas pedal, they would shoot a stream of gas into carb to start engine...
even if choke was tied open, you could still press gas pedal, shoot gas into carb, and start engine...when I pump gas pedal, it doesn't shoot gas into carb...once engine does start, it runs fine
Old 08-04-2011, 08:40 AM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Sounds like the fuel is leaking down back to the tank. How old is the fuel pump? If you cant answer that then, go ahead and buy a new one. Also would really check the accelerator pump to see if its worn out. Would also check the condition of the rubber lines all the way back to the tank.
Choke sounds like its doing its job, just sounds like the fuel delivery is having issues getting to the carb.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-04-2011, 09:15 AM   #6
slowboy
slowboy's Avatar
Smitty
fuel pump is about 15 yrs old, at least...put new one on there at least that long ago...
also, bought this Quad 3 or 4 months ago from Auto Supply... [remanufactured/rebuilt]...
just cranked truck this morning, pumped gas pedal 4 or 5 times, and it fired right up...
could accelerator pump be worn out, and still look new...
took it out a couple weeks ago and it looked good...
just took fuel line to carb loose...turned motor over...shot stream of gas out hose the size of hose's inside diamater [1/4"]...I'd say fuel pump is ok...?
Old 08-04-2011, 09:20 AM   #7
geezer#99
geezer#99's Avatar
Yup. Accelerator pump. Plugged discharge port or checkball stuck. Try this link.
Sean does good things to your carb. Or rebuild it yourself or find a good mechanic.
http://www.smicarburetor.com/
Old 08-04-2011, 09:43 AM   #8
slowboy
slowboy's Avatar
is there a way to check discharge port to be sure it isn't stopped up and clear it, if it is stopped up before I have to take carb apart...
uh...I was thinking discharge port was where gas shot into carb from fuel line...is this correct, or is discharge port under check ball...
Old 08-04-2011, 10:11 AM   #9
cdowns
cdowns's Avatar
have you changed out the fuel filter inside the carb inlet recently?
Old 08-04-2011, 11:19 AM   #10
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by slowboy View Post
...also, bought this Quad 3 or 4 months ago from Auto Supply... [remanufactured/rebuilt]....
Sometimes mentioning what parts have been replaced at the beginning helps so we won't give a lengthy, boring answer...
After you run it for a few minutes, remove the breather and manually move the throttle. If it squirts gas than you know the pump is working.
Also, after about half hour, have someone start the engine while you look at the exhaust to see if you see black smoke which would indicate fuel leakage.
Even with a new carb, you could still have a problem. I've had to return a few in the past.
Old 08-04-2011, 12:09 PM   #11
slowboy
slowboy's Avatar
no filter inside carb inlet...inline filter on fuel line before carb...
Old 08-04-2011, 12:12 PM   #12
slowboy
slowboy's Avatar
took fuel line to carb loose...turned motor over...shot stream of gas out hose the size of hose's inside diamater [1/4"] ...I'd say fuel pump is ok...
seems to me if fuel pump wasn't working, I would have problems trying to drive truck ...ie [no gas to carb]...truck runs fine once started...
ps...my truck don't smoke any at all
Old 08-04-2011, 12:14 PM   #13
slowboy
slowboy's Avatar
just got through driving truck for 2 hours...no problem
Old 08-04-2011, 12:24 PM   #14
68gmsee
Active Member
68gmsee's Avatar
Sorry. I was referring to the accelerator pump not the fuel pump.
Old 08-04-2011, 03:09 PM   #15
71meangreenc10
15 years???? I would replace it.....Hard to tell about the volume without measuring it.
The accelerator pump has a rubber gasket that usually cracks and fails.
Smitty
71 C30 Wrecker
