Old 08-03-2011, 10:26 AM   #1
rustierthanyours
Got a tough starter question for the pros
Hello I am a new member so be gentle.... I am working on a 62 gmc truck I installed a 292 I6 out of a 71 chevy truck that had the granny low 4 speed . I thought a great idea to run a nv3500 5 speed manual trans I had left from a parts 90 s-10. The clutch , pilot ,and bellhousing all bolted right up. Now for the problem. I cannot find a starter to fit , The 292 has the straight accross starter pattern but the large flywheel ..... Is there a starter out there that will bolt up ? I have tried 6 different ones now and the parts store is getting pissed. PLEASE HELP... I am making a bit of a rat rod out of this truck but don't want to have to hand crank it. Thanks
rustierthanyours is offline   Reply With Quote
Old 08-03-2011, 10:49 AM   #2
bw4sale
bw4sale's Avatar
Re: Got a tough starter question for the pros
I don't know if this helps, but I'm about to put a NV3500 in my 68. I was told I would have to use the flywheel off the 68 instead of the flywheel out of the '92 donor where I got the transmission because of the tooth count on it. Do you have the original flywheel off of the 292? You may have to use it instead.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 08-03-2011, 11:51 AM   #3
rustierthanyours
I did use the flywheel off of the 292 . I think I am going to have to find a smaller flywheel that hopfully will take my clutch . DO you know if a 292 is internally balanced? thankx
Old 08-03-2011, 09:07 PM   #4
awbrown
all 6 cylinder inlines were internal balance .. the flywheel you need is the small one ,most 283 and 230-250 had the small one .. cant remember if the 292 has 1/2 inch bolts but it might ...
awbrown is offline   Reply With Quote
Old 08-04-2011, 01:19 PM   #5
rustierthanyours
Thanks I'll try that option
Old 08-06-2011, 03:03 PM   #6
bama63
bama63's Avatar
try this one http://cgi.ebay.com/ebaymotors/SBC-B...Q5fAccessories fits both 153 and 168 tooth flywheels
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
