Old 08-03-2011, 01:12 PM   #1
ky_kid
ky_kid's Avatar
Aligning steering wheel
I am wanting to straighten out my steering wheel. I have had the alignment checked and everything is straight. The truck does not pull to the left or right when driving, just the wheel sits slightly to the left when going straight.
Could I align the wheel or the column easily? Or could it be something else?
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift
ky_kid is offline   Reply With Quote
Old 08-03-2011, 01:24 PM   #2
J Knight
J Knight's Avatar
Re: Aligning steering wheel
Because of the horn connection you can't change your wheel position on the shaft.
The way to change it is to adjust your tie rod sleeves.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 08-03-2011, 01:33 PM   #3
ky_kid
ky_kid's Avatar
That makes sense. Is this something I can do in the driveway?
Old 08-03-2011, 01:36 PM   #4
njlimbaugh
You can't do this in the driveway and be guaranteed of the toe-in being right. Any alignment shop can do this for you; unfortunately it's going to cost something, but if you do it at home it needs to be checked anyhow.
njlimbaugh is offline   Reply With Quote
Old 08-03-2011, 01:42 PM   #5
ky_kid
ky_kid's Avatar
Thanks for the tips. I was hoping I could do it myself without needing an alignment because what shops charge is a rip-off in my opinion...
Old 08-03-2011, 01:47 PM   #6
Pop's C-10
Pop's C-10's Avatar
If tha alignment was checked & it is fine..and you mess with tha tie rod ends, tha alignment will be off..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 08-03-2011, 01:49 PM   #7
ky_kid
ky_kid's Avatar
Yeah that's why I was hoping I could make the adjustment in the steering column somehow.
Old 08-03-2011, 02:10 PM   #8
Keith Seymore
Keith Seymore's Avatar
Wait! For a K truck, you can adjust the fore/aft drag link (between the steering gear and knuckle), without touching the tie rod or affecting toe-in. That will change the steering wheel alignment.
It's an easy driveway fix....
...not so, for a 2wd, which is how the guys are answering so far.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-03-2011, 02:16 PM   #9
ky_kid
ky_kid's Avatar
That is great news! How would I make the adjustment?
Thanks Keith!
Old 08-03-2011, 02:18 PM   #10
Keith Seymore
Thanks Keith!
Loosen the clamps and rotate the adjusting sleeve to lengthen or shorten the drag link as desired.
Like doing the tie rod ends, only there's only one and it goes fore/aft rather than cross car.
K
1979-1986
1986 - 2019
Old 08-03-2011, 02:22 PM   #11
ky_kid
ky_kid's Avatar
Thanks again I will go check it out now.
Old 08-03-2011, 02:31 PM   #12
ky_kid
ky_kid's Avatar
Are we talking about the long "sleeve" that runs almost the entire length between the front tires? I looks like it has a nut tightening each end with a margin of threads showing on each side.
Am I on the right track? And do I need to put it on jack stands when doing this?
Old 08-03-2011, 02:35 PM   #13
ky_kid
ky_kid's Avatar
Nevermind I found it. Do I need to jack it up to make the adjustment?
Old 08-03-2011, 03:10 PM   #14
88bagedntaged
88bagedntaged's Avatar
No I did n't have to jack mine up. I left the key in the unlock so the steering wheel moved and adjusted it till the wheel was strait. However you need to make sure that when you stop the truck that you were going very strait in the process of stopping. I backed all the way down my road and then just coasted to the fron of my drive way keeping an eye on where the wheel was to where I know it was like on the highway. and it is strait now.
88bagedntaged is offline   Reply With Quote
Old 08-03-2011, 03:35 PM   #15
Keith Seymore
agree.
The other thing you can do is drive straight down the road and mark where the steering wheel is (put a line from the steering column to the base of the wheel).
Then go park and line up your mark. This will tell you the road wheels are straight ahead.
Adjust the steering wheel so that it is straight at that point and you should be good to go.
K
1979-1986
1986 - 2019
