08-03-2011, 01:26 PM | #1 |
New Project!! '63 SWB Fleet My Build Thread
Starting this thread for my build on my 1963 SWB Fleet. Will post pics tonight.
1966 LWB Stepside......SOLD 1963 SWB Fleetside.....Current Project I hate all fords. |
08-03-2011, 07:03 PM | #2 |
Re: New Project!! '63 SWB Fleet My Build Thread
Sweet! Tuned in.
1963 Destiny Build Log |
08-04-2011, 12:07 PM | #3 |
here is a quick shot we took last night, dark out but I will get some more today after work. Anyone know anything about the Inline 6 for the 1963 year? I also need to drain the fuel tank, is there a way to drain the tank without removing it from the cab?
08-04-2011, 03:33 PM | #4 |
i love that patina. great looking rig
08-04-2011, 04:04 PM | #5 |
i know! this thing shows good age, I don't even want to paint it
08-04-2011, 04:58 PM | #6 |
Double 6's
great Patina! lucky!! As for the gas tank, on my '66 the fuel line comes out the bottom on the passenger side(steel) then goes to rubber fuel line. I just took that off and let it drain in a pan. ended up having to remove the tank to clean it all anyhow. Hope it works out!
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
08-04-2011, 05:35 PM | #7 |
Thanks, I like 'em rusty haha. Ya I figured there was no easy way to drain the tank. Anyone know where to pick up a good carb for an inline 6?
08-08-2011, 06:24 PM | #8 |
ok so tank cleaned, oil changed, battery installed, NO START.... I have learned that this truck has the OG 230 inline 6 I was hoping it had the 292.... anyway, no fuel to the carb, old fuel in the pump, replacing the pump, coil, distributor, wires, and plugs this week, hopefully it starts after all that is done and I can move on to brakes and suspension....
08-08-2011, 07:56 PM | #9 |
Check The Champ, Demonstrator
Apparently you can rev a 194,230 & 250 higher than a 292. Some small block chevy parts will go right into the 6 if your looking to get more power out of it. I have a 250 in mine and I enjoy the power, along with the fuel economy. These things are basic mechanics. Get yourself a shop manual for insight into any problems that might creep up. Also there's great free advise here as well.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-09-2011, 12:41 AM | #10 | |
http://67-72chevytrucks.com/vboard/s...ight=250+turbo you pretty much got an easy maintenance-gas saver-potential dragster under your hood. good score. |
08-09-2011, 08:42 AM | #11 |
Looks good - watching this one
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
08-09-2011, 09:05 AM | #12 |
Hollister, CA.
Sweet patina man .... and of course the year of choice too !!!
Sick bro !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-09-2011, 02:27 PM | #13 |
thanks for all the positive comments and suggestions, i am turning into a big fan of the inline 6 in all the different sizes, 230,250, and 292, I had a 327 in my '66 and that was a thirsty truck, i am interested in this 350 piston upgrade, but let me get what i have running first
08-11-2011, 05:16 PM | #14 |
took some photos this morning before i left for work,
08-12-2011, 06:16 AM | #15 |
don't forget the inline gas filter under the truck on the frame!
08-12-2011, 11:19 AM | #16 |
right, i will be sure to check that. i am going to replace the fuel line from the pump to the carb with neoprene line instead of steel and install an inline filter between the pump and carb, I am waiting for the fittings, NAPA did not have them in stock...I HAVE to get this truck started this weekend, too bad the heat index here is going to be like 115 all weekend not the best weather to be under the hood outside.
08-12-2011, 11:37 PM | #17 | |
Edit: I also have a DELCO HEI distributor that I pulled from that same motor with the cap, rotor and wires still attached. One hot wire to the IGN post and you are good to go. Sam Last edited by samuellg1977; 08-12-2011 at 11:44 PM. Reason: addition |
08-15-2011, 12:19 PM | #18 | |
I set the timing, finished up repairing the fuel lines and checking for clogs in the fuel lines and finally came to the conclusion that the fuel pump HAS to be bad, I disconnected the fuel line from the sending unit at the tank and I was able to blow through the line easily, which tells me the line isn't clogged. Another indicator was that when I took the old pump off, it was full of old gas still, so, if the pump was working it should at least pump that old gas out of the pump and up to the carburetor, RIGHT???
08-15-2011, 01:17 PM | #19 |
Senior Enthusiast
If you have a factory fuel filter it will be on the passenger side frame rail under the door near the tank. My 1960 GMC has one, and the filter correct filter cartridge is Napa part number FIL 3271. I’m not sure if 1963 Chevy trucks came with this filter or not, but if it did this may save you some searching.
https://www.napaonline.com/Catalog/C...271565398&An=0 |
08-15-2011, 01:44 PM | #20 | |
08-15-2011, 03:01 PM | #21 | |
Sam |
08-15-2011, 03:34 PM | #22 |
Senior Enthusiast
If you're running a mechanical fuel pump, I'd just put a filter after the pump and before the carburetor. Mechanical pumps are very forgiving. Electric pumps are not, and need a filter before the pump.
08-15-2011, 03:36 PM | #23 |
OK, I did put an inline filter between the pump and carb, that should be good for now, new fuel lines are over $100 on lmc so I didn't really want to make that repair if i didn't have to!! Looking for a new fuel pump if anyone has one
08-16-2011, 12:28 AM | #24 | |
60-66 Nut
That was on the '60-'62's only, and maybe just on the GMC's. I don't know if the '60-'62 Chevys had that canister filter or not.
08-16-2011, 12:11 PM | #25 |
yeah, mine does not have the inline filter....must be on the 62 and earlier models
