Old 08-03-2011, 04:56 PM   #1
Zulu
Zulu's Avatar
Show me your Altenator brackets!
I'm trying to make up my mind as to which brackets to use, Driver side only.
Thx.
Zulu is offline   Reply With Quote
Old 08-03-2011, 07:47 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Show me your Altenator brackets!
Here are mine. Drivers side.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-03-2011, 09:49 PM   #3
Zulu
Zulu's Avatar
Factory! What year? Thx
Old 08-03-2011, 10:52 PM   #4
FLcustom10
Here's mine - factory 72, but I'm not sure if it's going to work with these valve covers. Looks like I'll have to take the valve cover off, hook up the alternator and hope I can get the valve cover back on. I'll be watching for other ideas.
FLcustom10 is offline   Reply With Quote
Old 08-03-2011, 10:59 PM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Here's a little variety for ya!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-03-2011, 11:24 PM   #6
1972RedNeck
1972RedNeck's Avatar
I've got the same bottom bracket as FLcustom10 but with this for the top adjuster.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-04-2011, 12:07 AM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
custom i need to rechrome it
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-04-2011, 12:44 AM   #8
AustinScott
AustinScott's Avatar
here is what I'm Running, ( Short Water Pump)
here you can see how I modded the bracket so I could run power steering
Here it is all together
hope that helps, I also have all the stock brackets for the driver alternator with the stock ram horn exhaust if you want to see them I can post them up fo ya
AustinScott is offline   Reply With Quote
Old 08-04-2011, 12:53 AM   #9
dukcaln
dukcaln's Avatar
no need to post my pictures...same set up as austinscotts... looking good man
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 08-05-2011, 09:38 AM   #10
Zulu
Zulu's Avatar
Thanks guys, AustinScott that does help I like that setup, no need for the stock brackets pics. I'm hoping to see more setups before making up my mind, I'll be using a Jegs 1 wire Altenator http://www.jegs.com/i/JEGS-Performan...oductId=750748
Old 08-05-2011, 11:19 AM   #11
Andy4639
Old member
Andy4639's Avatar
Wink Re: Show me your Altenator brackets!
Mine is a stock 71 setup as far as I know. It was on the 307 when I bought the truck.
