Old 08-03-2011, 06:30 PM   #1
dfwright
dfwright's Avatar
95 Suburban - Left Exhuast Manifold cracked
Is it possible to remove and replace the left side exhaust manifold without removing the whole power steering reservoir and alternator, and the bracket that connects them?
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 08-04-2011, 12:46 PM   #2
scotts62
One day...
scotts62's Avatar
Re: 95 Suburban - Left Exhuast Manifold cracked
Maybe just the power steering and um bolt the bracket that bolts to the manifold. Been a while since i have changed one but ill look at mine and see.
Scott
93 crew cab build
Project 62
Old 08-04-2011, 05:28 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
you can unbolt the bracket from the motor and leave the pump and the alternator on the bracket. that will give you plenty of room and its not a lot of work
95 S_Trucker is offline   Reply With Quote
Old 08-04-2011, 07:13 PM   #4
dfwright
dfwright's Avatar
I ended up taking the power steering pump loose, with the bracket still attached to the pump. Fortunately, neither the alternator nor the alternator bracket needed to be touched. Thanks for the replies, it is much appreciated!
