Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-03-2011, 07:04 PM   #1
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Wheel and drag radial questions
I'm getting ready to purchase some 10" wide 15" truck rallys and MT ET Drag Radials and wanted some feedback on the rear wheel backspacing and tire size. I'm unsure if I should get the rears in 4.5" backspace or 5" backspace? The wheels this truck had on when I bought it were 16's and it had the '68 Dana44 in....they rubbed the inside on turns, etc.
I was planning to buy 315 or so wide rear drag radials...but now see theres a TX drag racing series that limits rear size to a 275... or 28x10.5. The truck will get a different staggered combo later on in its life (when repainted)....like 17x8 fronts and 18x10 rears...which would probably take it up to a 30" rear. The truck does have a rear fuel tank to put more weight over the tires...but it doesn't seem to help.
So.....with a truck and the way this thing spins 275's on the street (1st can't grab and neither can 2nd until over 1/2 way thru its range) I'm afraid a 275/60-15 drag radial isn't going to be enough. I had planned on a 315/50-15 or even going up to a 30" tire with a 315/60-15 and lowering my rear gears from 3.73 to a 4.10 or even 4.56.
28" tall rear tires would avert the extra rear end expense tho.
So guys, help me out with your opinion.......4.5" or 5" b.s. for the 10" rears? Truck is a '68 short/step side and now has a '72 12 bolt.
And.......315 rears? or 275 rears to keep from being disqualified in some series? Or is this series a rare thing and just go with the biggest I can get to assure no traction issues? (315's?) And....stick with the 28"s? or make the move to 30"s now. I'm not even sure what class this thing would go under...other then just running a bracket series. On paper....truck should run 12's or so (or better).
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-03-2011, 08:13 PM   #2
fair1138
Re: Wheel and drag radial questions
I had 10" wide rims, I think they were 6"bs. I went with MT 29x15.50-15 Sportsmen. The bed is cut to fit the tire, and the tire doesn't stick out.
Since then, Ive went with a 12" wide rim.
fair1138 is offline   Reply With Quote
Old 08-03-2011, 09:43 PM   #3
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
10" wide you can go 5-6" BS but the 6" sits deep in the fender on a 10" wheel,
12" wide w/ a 7.5 back space works great.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 08-03-2011, 09:56 PM   #4
68GMCCustom
I don't want to have to mod the bed until time for paint....so it would need to fit with the bed uncut.
Kurt -
Old 08-04-2011, 12:42 AM   #5
67_SS396
The 275 class is real new around here. It makes for some great heads up racing and hope it sticks around. Some of them used to run King of the Hill and True 10.5. They are running low 5's on a 275 drag radial now and I remember when that was tough to do on a true 10.5 tire. If you get your suspension dialed in, you should be able to hook on a 275. For some even better heads up racing with no tire size requirement, check out TX Triple Threat. These are all the guys from KOTH after it disolved. A bunch of us will be headed to Redline the 20th of this month to watch some good heads up.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 08-04-2011, 01:22 AM   #6
Super73
Super73's Avatar
Playing with Drag radials for some time now, I would advise against a 315 on a 10" wheel. It seems most of the heavy hitting DR guys stretch the tire a bit to get the full contact patch down. A 275 would be right on a 10" and a 315 is right on a 12"..
You would be suprised what a sticky tire does for you. You would also be suprised how a 28" tall tire works compared to a 26" tall tire.
If you are going 10", go 275 in a 28".. It will work a lot better than a 275 26".
If you can go with a 12", 7.5" back space, get a 315/60/15 and put some more gear in it.
But even then, with enough motor, converter, gear, you can fry then even with the super tall 1st gear of a power glide. I have 315/60/15 MT DR's and I left a couple good 100' strappers on the way to the chassis guy today (haven't driven the truck in a couple months).
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-09-2011, 10:58 PM   #7
Bad70sbchevy
Bad70sbchevy's Avatar
Back when my uncle had the truck, he used to run mid 12s on 275 Cordovans on a 15 inch rim (4.11 gears). Said the truck had no problem hooking up with the stock suspension and Koni adjustable shocks. Now as far as on the steet, not so much . Keep in mind this is NOT on a cheater slick.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 08-09-2011, 11:17 PM   #8
69trk
69trk's Avatar
Here's mine on a 8" rim with 275/28's. I tried a 295 and they looked way to tall on my truck. Plus i didn't want to change gear.. I had a set before but i couldn't get them to hook at all on the transbrake, but hooked pretty good footbreaking...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
