Old 08-03-2011, 10:05 PM   #1
ubtripn
ubtripn's Avatar
New 4 row Radiator, New Fan, New Water Pump and Stat - still running hot!
I just don't get it. This was a NAPA 4 row radiator. I jacked the front up when I filled and burped it. The pump and fan are new. Its driving me crazy. I couldn't put the shroud back on but still, that could not be it. I went around the block twice and hit 220. Somebody said it is possible for the water pump to look identical but rotate the other way. That is the only thing left I can think of.
What do you all think?
ubtripn is offline   Reply With Quote
Old 08-03-2011, 10:34 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: New 4 row Radiator, New Fan, New Water Pump and Stat - still running hot!
Do you have any pictures of your pulley and belt setup you can post?
You also may have a blockage somewhere in your water jacket.
LockDoc
Leon
Old 08-03-2011, 10:44 PM   #3
Lee H
Lee H's Avatar
How are you measuring the temp?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-03-2011, 10:47 PM   #4
redmonster
redmonster's Avatar
having the same problem and i found some information that a fan shroud should help
WITNESS
Dont be like me be better than me
redmonster is offline   Reply With Quote
Old 08-03-2011, 10:49 PM   #5
68chevyfuelie
68chevyfuelie's Avatar
That's my first question too....we had a '56 Belair 2 weeks ago that was "overheating"....aftermarket electric gauge showed 220, original mechanical gauge read 190. We used a temp gun on the intake, block, heads, etc to rule out the temps being read.
A water pump with straight fins on the impeller shouldn't care which direction water flows, you have to be careful when the impeller blades are curved one way or the other.
68chevyfuelie is offline   Reply With Quote
Old 08-03-2011, 11:50 PM   #6
ubtripn
ubtripn's Avatar
Which gauge was right?
I am using a new mechanical gauge.
I could not fit the shroud because the rad is thicker so I am going to shave it down and install it. I started to wonder if there is some type of necessary relationship between the flex-blade fan and shrouds. (I hate flex fans)
Red Monster - what did you learn about the shrouds?
I will try to get a pick. My worst fear is a water jacket blockage.
I did lift the front when filling to ensure the heater core was below the radiator.
Old 08-04-2011, 12:00 AM   #7
68chevyfuelie
Is the water/coolant physically overheating though? Not too sound like a jackass, but you need to start with the basics.
Is the thermostat opening, the upper rad hose getting hot? Is the coolant bubbling and hissing? Rad cap working okay?
I disagree (as an opinion) with needing a shroud for the amount of driving you are talking about. I think you need to determine if the mill is overheating (with no help from the rad) vs. everything working together ('stat open, good coolant flow, etc.).
Also, sometimes overlooked, if it's an A/C truck, if the condenser is plugged, the rad will receieve no airflow. Sometimes those little things when overlooked will bite you in the ass trying to chase a problem.
Old 08-04-2011, 12:04 AM   #8
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
take it to a smog machine and have them check for gases at the radiator, coming from the heads or block possible
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-04-2011, 12:18 AM   #9
ubtripn
ubtripn's Avatar
Yeah I have good flow, no thermostat right now, I have one waiting to go in but I figured a 4 row radiator with no stat should run very cool.
Thanks Fastwilly - I will do that.
Coolant boiled at 215 and expelled out.
I just burped it more, and could see the coolant running out of the flues with the cap off and the flow increased with RPM. Bubbles came out and now it is running 190 (88 degrees outside) until I stop to idle and it climbs to 210 then 220. I am hoping the shroud will fix that.
Old 08-04-2011, 06:08 AM   #10
cdowns
cdowns's Avatar
i always take a known good thermometer and take the actual temp of the liquid to see if gauges are accurate
Old 08-04-2011, 07:21 AM   #11
MagmaJct
MagmaJct's Avatar
I'm impressed that no one has asked one key question:
Does it over heat with high speed driving or low speed driving. This is critical. If the fan shroud is missing the cooling fan is almost completely useless and it'll pull air from the space between the fan and the radiator.
The shroud forces the air to be pulled through the radiator at low speeds (when the fan does most of its work.)
Also, this is further proof that removing the thermostat, or running with a cooler thermostat doesn't prevent over heating. The thermostat sets the minimum coolant temperature, not the maximum. All a thermostat does is prevent the cooling system from functioning until a minimum operating temperature is met, then it "turns it on" so to speak.
If the cooling system is broken, it doesn't matter when it's "turned on". My advice? Re-install the shroud, find a way, then see what happens. If the problem isn't solved, don't think the shroud wasn't the problem, look at it as a "contributing factor" that has been eliminated. Details matter!
MagmaJct is offline   Reply With Quote
Old 08-04-2011, 07:29 AM   #12
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Have you checked the coolant for content? A small head gasket leak can drive you nuts trying to locate. Have it checked. (Don't ask how I know)
TobyArnot is offline   Reply With Quote
Old 08-04-2011, 07:38 AM   #13
MARKDTN
X3. A fan shroud is critical to force air through the radiator
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-04-2011, 09:06 AM   #14
ubtripn
ubtripn's Avatar
Great point ll especially MagmaJCT - I did not re-install the shroud so I will be modifying it to fit today. (I replaced the 3 row with a four row)
You were right, slow speeds and idle were the problem and I could feel no air being pulled through the rad at idle. I think you nailed it. Going to do the work today and will repost tonight. Thanks all!
Old 08-04-2011, 09:06 AM   #15
LockDoc
LockDoc's Avatar
You need a thermostat, otherwise the coolant travels through the radiator too fast to be cooled. I think that, plus no shroud are contributing factors to your problem, especially for in town driving.
Just my 2¢ worth.
LockDoc
Leon
Old 08-04-2011, 09:08 AM   #16
mpotts64
mpotts64's Avatar
I had heating issues as well, new rad, all new hoses, new t-stat, flushed the system, had a shroud and all and still overheated, come to find out the clutch fan was not working so there was no air being pulled through when idling, I took the clutch fan off and drilled and put bolts through it to make it a direct drive, it hit 111 degrees here yesterday and it stayed right on the mark, did not run hot, that baby is pulling air now, will blow the tags on the radiator hoses now, best of luck
No one ever fell to the top of a mountain.
When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend -
mpotts64 is offline   Reply With Quote
Old 08-04-2011, 10:46 AM   #17
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
The thermostat needs to be in for transfer of heat from the block back to the radiator. if water flow is two fast it will not transfer heat. Shroud needs to be on to route the air flow. Also improper timing will affect How hot or cool the engine runs but. and then if you have a clutch fan is it operating correctly. that all i can think of.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 08-04-2011, 11:08 AM   #18
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Where do you have your temp sending unit installed? It should be in the drivers side cylinder head.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-04-2011, 11:14 AM   #19
mbgmike
Have you solved this yet? I suspect bigger problems then just a shroud. we run engines on test stands w/o shrouds and they don't overheat. Even at high rpm's. Cars and trucks years ago never had them. If your blade is too far back from the radiator i could see that it may have an effect.
mbgmike is offline   Reply With Quote
Old 08-04-2011, 11:25 AM   #20
mbgmike
Gary
does the sending unit even work sorry
Old 08-04-2011, 02:48 PM   #21
ubtripn
ubtripn's Avatar
Still working on shroud install And stat install. Will update when done. Sending unit mounts by the stat.
Old 08-04-2011, 02:51 PM   #22
ubtripn
ubtripn's Avatar
I thought a thermostat either was open or closed not metering in between. Learn something new everyday.
Old 08-04-2011, 02:53 PM   #23
GASoline71
GASoline71's Avatar
Sending unit by the stat is prolly why it's reading hot. Mine is in the stock location in the drivers side cylinder head on my SBC and rarely reads over 185 to 195. I have a 180 degree stat in it as well.
I used to have a 4 row stock type radiator in there and now have a 2 row aluminum unit. The temp readings were the same with both radiators.
Gary
Old 08-04-2011, 03:52 PM   #24
wicky
wicky's Avatar
How long have u had this truck. Is it a big block or small block. Sounds stupid but i just bought my first big block in april it ran around 215. So i started thinking the same thing ur doing. I talked to couple people round my area and they told me bbc will run little hotter. But i agree now shroud and thermostat is not helping
wicky is offline   Reply With Quote
Old 08-04-2011, 05:05 PM   #25
Dano69c10
Dano69c10's Avatar
Also make sure you're not running lean.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
