Old 08-03-2011, 10:15 PM   #1
Chevy4Life
Chevy4Life's Avatar
Vetteworks stock fuel pump tank adapter
This is a great way to add a factory LS fuel pump to any steel rear mounted tank. I have a Early Classic stainless that I bought before I decided to go EFI and this worked perfect. I'm using a 05 Silverado pump, but it also fits F-body and Vette pumps.
4 tack welds hold it in place and it uses the GM gasket to seal.
Chevy4Life is offline   Reply With Quote
Old 08-12-2011, 11:36 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Vetteworks stock fuel pump tank adapter
Price?
Hart_Rod is offline   Reply With Quote
Old 08-12-2011, 11:58 AM   #3
Chevy4Life
Chevy4Life's Avatar
$46
http://www.vetteworksonline.com/cata...dce47e98ab1129
Old 08-12-2011, 12:04 PM   #4
Hart_Rod
Hart_Rod's Avatar
Not a bad price for the adapter and the pump: http://www.vetteworksonline.com/cata...dce47e98ab1129
Old 08-12-2011, 12:15 PM   #5
Chevy4Life
Chevy4Life's Avatar
That's just for all the fittings to plumb it so you can use the fuel pumps internal fuel regulator. And it seems kinda high.
Old 08-12-2011, 12:18 PM   #6
Hart_Rod
Hart_Rod's Avatar
agree. I meant to post this: http://www.vetteworksonline.com/cata...dce47e98ab1129
Old 08-12-2011, 12:28 PM   #7
Chevy4Life
Chevy4Life's Avatar
True! If I had a returnless fuel rail I'd definitely run the internal regulated pump. You wouldn't even need the corvette filter and it would be just 1 line from the tank to fuel rail.
