Old 08-03-2011, 10:45 PM   #1
redmonster
redmonster's Avatar
Fan Shroud
i have a I6 250 recently rebuilt as some may know but have had trouble keeping it cool
i found information that putting a fan shroud to direct more air would help is this true if so which fan shroud would fit best
WITNESS
Dont be like me be better than me
redmonster is offline   Reply With Quote
Old 08-03-2011, 10:49 PM   #2
bosco200
bosco200's Avatar
Re: Fan Shroud
You shouldn't have trouble keeping a 250 cool, mine runs 195 degrees while pushin 3,500 rpm
bosco200 is offline   Reply With Quote
Old 08-04-2011, 07:32 AM   #3
MagmaJct
MagmaJct's Avatar
Re: Fan Shroud
It depends. Do you do a lot of stop and go driving? With or without loads? Driving around at 3500rpm suggests a lot of high speed driving. What's the ambient temp?
A fan shroud will help if you drive below 45 MPH or stop for traffic lights, or experience traffic.
Shrouds are important, and I'm seeing a common thread developing here.
MagmaJct is offline   Reply With Quote
Old 08-04-2011, 07:51 AM   #4
ERASER5
ERASER5's Avatar
Re: Fan Shroud
These trucks with 250's did not come with a shroud, just a flat plate over the fan to protect you a little. Unless you build a high HP 250, a shroud may make you feel better, but not needed.
The V8's all got factory shouds I believe. If I really wanted a shroud, I would start there.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-04-2011, 10:52 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Re: Fan Shroud
I have a 250 in mine and I also used to have a heating problem after I rebuilt it.
There were no head gasket leaks or other problems with the engine that would cause it to run hot.
Things I did on mine:
I bought a temp indicator cap at Auto Zone to make sure it was running hot and not the gauge being wrong.
Then I checked all of the hoses and they were all good.
Made sure the t-stat was working properly. Tested it in a pot of water with a cooking thermometer and checked that it opened up at the stated temp. It did.
Experimented with percentage of anti freeze to water. No help.
Replaced the radiator cap with the recommended one. No help.
Replaced the water pump. No help.
Had the radiator rodded. No help.
Installed a double core radiator. No help.
As a last resort, I installed an overflow container to prevent fluid loss and that finally fixed it. Temp stays at the normal level even idling in the hot days.
Not saying it will fix yours, but it's a cheap way to find out and/or prevent fluid loss.
68gmsee is offline   Reply With Quote
