08-04-2011, 12:51 AM | #1 |
homemade coolant resivor ideas please
so i want to do a homemade coolant resivor. i have heard of some cheap builds. like beer cans that have the screw top and water canisters/bottle with screw top..... I would like some ideas in this area to do one my self... anybody got pictures of thiers or a link to a thread on how to build one...parts used ect.....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
08-04-2011, 12:54 AM | #2 |
~Rest In Peace~
Re: homemade coolant resivor ideas please
i just got a small plastic one from jegs 20 dollars ,it has petcock on the bottom ,havnt put it on yet .
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-04-2011, 01:06 AM | #3 |
I bought a windshield washer fluid tank and bracket from LMC, about $15. It looks stock. I mounted it opposite the regular washer tank, it fit perfectly behind the battery and looks like it was meant to be. The cap even has a tube that goes to the bottom of the tank so when the rad cools off it allows the coolant to be sucked back in the rad. Make sure you buy a two way radiator cap, they have a second valve that allows the coolant to be sucked back in when it cools off.
Posted via Mobile Device |
08-04-2011, 06:00 AM | #4 |
I have a windshield washer container as an overflow tank and it tucks nicely into the "teacup" so all you can see is the overflow hose.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-04-2011, 06:04 AM | #5 |
you could get one of those jugs that they have in hospitals for patients to pee in and put a skull decal on it // bet that wood b a one of a king overflow container
08-04-2011, 07:25 AM | #6 |
Here are a few pictures of the one's I've saved.
I need to do the same thing too !!! The first one was said to have come out of a GM "G" body.
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
08-04-2011, 09:12 AM | #7 |
That bottom one (blue) could be made with PVC if you have that laying around.
08-04-2011, 11:33 AM | #8 |
I like the aluminum water bottles from Walmart. $5, muffler clamp slitely spread to fit. Drill hole for tubing to go through lid, then put section of tubing to go to bottom of bottle. Cut tip at angle to avoid sucking on bottom of bottle. Drill 2 holes for clamp in fender lip, down low so hood will clear bottle top. Clamp on. I used one for my washer bottle.
08-04-2011, 11:34 AM | #9 |
1972 C/20
Jack Daniels bottles are cool! Empty of course.
08-04-2011, 12:14 PM | #10 | |
so, I like the blue one above, do i need just a hose to the top of the canister.... of is there a need for a hose to return from the bottom of the canister back to the radiator... I dont have anything on the truck now, and once in a while I get a drip out of the fitting just under the cap.... I dont have it blocked...
08-04-2011, 12:15 PM | #11 |
Active Member
I used some 2" black pvc pipe from Lowes and two caps. Glued one cap on one end and left the other unglued (top). Drilled a hole for the hose to go through and clamped the pipe to the radiator support.
08-04-2011, 12:19 PM | #12 |
cool so no need for a return line right, just a line in the top so the canister catches the overflow when it flows. right?
08-04-2011, 12:25 PM | #13 |
Local Redneck Authority
Just make sure there is a means to vent the cannister, otherwise it won't be of much function. Oversized hole for the tube would work just fine with the tube going to "near" bottom of the tank.
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor Last edited by propanemudtruck; 08-04-2011 at 12:25 PM. Reason: cain't speel |
08-04-2011, 12:34 PM | #14 |
if you dont change radiator cap the coolant just stays in the overflow tank and does not go back into radiator
08-04-2011, 12:43 PM | #15 | |
Active Member
I put the hose inside just touching the bottom and cut it at an angle to allow flow. THen filled the radiator to the top and left the overflow tube empty. As engine warms water flows to the reservoir and is sucked back in when it cools down. This way the radiator is always full. Apparently, my truck likes a full radiator. The cap should be one that is able to suck the fluid back in when it cools down. |
08-04-2011, 01:55 PM | #16 |
i will go out and take a picture then post what I am working with
08-04-2011, 02:06 PM | #17 |
cap I am working with......
08-04-2011, 04:51 PM | #18 |
The blue one is mine. I purchased that from Summit and on hte bottom it has a petcock, no return line.
08-04-2011, 05:26 PM | #19 |
A two way cap will have a round valve on the inside, you should be able to pull on it and have it open, they are spring loaded and when you let go it should seat. As the coolant cools it creates a vacuum, sucking the valve open and refilling the rad with coolant from the overflow tank. I can't tell if yours is correct without seeing the bottom, they all look the same from the top. (most anyway!)
08-05-2011, 11:30 AM | #20 |
BOHICA
would a jack daniels bottle break due to heat and cool over time? How much coolant capacity do you need? 1.75, or would a liter bottle work?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
08-05-2011, 02:58 PM | #21 |
I don't think bottle would be good.... I think the cool looking beer cans with the screw lids.... I would inmagine if the truck used very little to non extra freeze that a liter would do it....
08-05-2011, 06:02 PM | #22 |
Check out this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=433972 I have an empty fire extinguisher I want to use, it may be too large though. The PVC seems to be a good option I should have some left over from my bathroom...
71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
08-05-2011, 08:05 PM | #23 |
man I got a few ideas now, just need to decide on one...LOL
08-05-2011, 10:39 PM | #24 |
Fabricate till you "puke"
I have a 3" dia chunk of driveshaft tubing (about a ft long)....both ends are capped & welded , feeds in from the bottom, & the overflow hose is out the top. Its ugly, but it works....never pukes on the street crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
