Old 08-04-2011, 09:08 AM   #1
1970jimmyb
Body parts
Hello everyone I just joined this forum because I recently purchased a 1970 Jimmy. I was wondering if anyone could help me out with a question I have. My jimmy needs some body work and I have parts trucks (pickups) to use. Will the fenders off a 72' gmc pickup fit on my Jimmy? Also the back quarter section of a fleet side and my Jimmy look the same. do these match up aswell?
1970jimmyb is offline   Reply With Quote
Old 08-06-2011, 07:41 AM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Body parts
All GMC fenders are the same except the 67 without the side marker. The fleetside bed side can be used as a replacement if it's a shortbed. There is a slight difference on the front bottom of the wheel well. A long bed section for the rear couple feet might also work, but might need a little hammer work to align it.
hgs_notes is offline   Reply With Quote
Old 08-06-2011, 08:04 AM   #3
dubds10
Stalker Nate
Re: Body parts
Welcome to the site. Good to see another BC boy here. Which Jimmy did you buy? I know of 5 that were on CL the past month.
Good luck with the build and take lots of pics.
Nate
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 08-06-2011, 01:54 PM   #4
1970jimmyb
Re: Body parts
Hey guys thanks for the replies. I bought the 1970 jimmy from Mission, its on 35'' super swampers, 454 bb, 3/4 running gear, 4 disc brake conversion, 4 speed. All the mechanical stuff is pretty good but the body just needs some work. I also cant get my fuel gauge working, it reads well above full all the time. I have been reading some posts on here about it and been testing and what not. I just have to do the ohm test but I am pretty sure I need a new sending unit. thanks again guys.
Brian
Old 08-06-2011, 04:17 PM   #5
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Body parts
Make sure you have a good ground first. You should be able to reach it from underneath.
Old 08-07-2011, 01:40 PM   #6
1970jimmyb
Re: Body parts
I see a ground coming from the unit housing going to the frame. I cleaned the end that attaches to the frame and put it back on but it made no difference. I also did the ohm test and it read about 9.5 and that seems about right for the amount of gas I have in it. Do you think maybe its not making good enough ground to the tank/unit housing? I talked to alot of people and they say most of the time its a wire or something and that the sending units are usually good to go.
Old 08-07-2011, 02:38 PM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Body parts
If you can reach the tank end if the wire and check the connection, then try it. The last one I messed with had a bad float, which would indicate empty if working. Sometimes the gages fail though or the printed circuit on the back of the gage set.
