Old 08-04-2011, 10:50 AM   #1
atarijake
Factory exhaust schematic?
Hello, I'm looking to run a new exhaust system on my 85 k10. It has a 305 with a sm465 4 speed transmission.
The guy who had the truck before me put a bunch of flex pipe exhaust tubing under it so I'm trying to figure out the best way to run all new pipes, keeping everything up as high as possible so it won't get knocked off when I'm off-road.
They way he ran the flexpipe hangs down and will get knocked clean off the first time I take it off-road... he ran everything horribly, so I can't use the same route.
So does anyone have a factory recommended schematic for running exhaust or any recommendations?
Thanks!
atarijake is offline   Reply With Quote
Old 08-04-2011, 11:03 AM   #2
veinbar
veinbar's Avatar
Re: Factory exhaust schematic?
I know that at my exhaust shop, if you explained what you wanted, they could make it happen. I just had dual 2.25" exhaust installed exiting behind the tires like stock. It was very tight and clean making it easy to access my trans and starter, leaving room for my rear mounted spare or hitch. They can throw it on a lift and describe their idea after hearing what you're looking for. I'm not sure that factory schematics will help you here.
2008 Yamaha Zuma 50cc - Daily Driver
1979 Chevrolet Bonanza SWB; 357ci, TH400, 3.73 Posi - Daily Driver
1976 Chevrolet Sport Van SWB; 355ci, TH350, 2.73 Open - Rape Free
1972 Oldsmobile Cutlass S; 455ci, TH400, 2.73 Open - SOLD (but I still claim to own it from time to time)
veinbar is offline   Reply With Quote
Old 08-04-2011, 12:01 PM   #3
Johnny Merder
Johnny Merder's Avatar
I used a $ 199 kit from LMC on my 79 1/2 ton and I thought it worked great. There isnt a exhaust shop around here that would put a dual exhaust system on a cat equiped truck. LMC's kits can have numerous exits, I chose stock exit true duals with 2.5 inch aluminized pipe. everything fits perfect. They also have y pipe setups for the single exhaust guys.
Johnny Merder is offline   Reply With Quote
Old 08-05-2011, 12:07 AM   #4
raceman6135
Dino burner
raceman6135's Avatar
Check out either the Walker exhaust website or the Maremont website. Both will have schematics to give you an idea about what was factory and what it looks like.
http://www.walkerexhaust.com/
http://maremont.com/
raceman6135 is offline   Reply With Quote
Old 08-05-2011, 06:05 AM   #5
GM72K10
Next!
GM72K10's Avatar
Lots of these pics in the factory parts book, diesel would be same as small block
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 08-05-2011, 09:28 AM   #6
atarijake
Awesome, thanks!
Old 08-05-2011, 09:59 AM   #7
Goldfinger
Goldfinger's Avatar
Mine Runs from the headers to a crossover pipe then spread to the side of the frame rails as soon as it hits the bed it raises in height ave the axle it forms a v look over it after that it spreads to clear the tire carrier and exits at the rear.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
