08-04-2011, 11:51 AM | #1 |
autozone brake booster
http://www.autozone.com/autozone/par...uestid=2621665 i was just looking around and found this. would it work. i have no brake booster. would it work.
08-04-2011, 12:34 PM | #2 |
Who Me?
Re: autozone brake booster
It looks like it might. Its comes with the bracket and master?
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
08-04-2011, 12:51 PM | #3 |
Says it fits '66 C10 2wd V8. That's pretty bad ass minus the pickle jar master.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
08-04-2011, 02:14 PM | #4 |
i am also interested in knowing if this would work? i called autozone and it comes with the booster,master, and bracket.......
here is the same one without the bracket.... http://www.autozone.com/autozone/par...41_0_8550_3186 and heres the same one without the master...... http://www.autozone.com/autozone/par...97_0_7889_5172
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
08-04-2011, 04:43 PM | #5 |
I saw an original 1972 stepside the other day with a v8, ps, power brakes, the booster looked just like that, but it did have a dual master cylinder( FYI I think a dual mastercylender rebuilt costs about $19.95 at autozone that was what I used. The only wrinkle I had in this deal was that I used captain fabs bracket and it moved the master cylinder in closer to the firewall. I had to shorten the shaft that went from the pedal to the booster, Kieth
08-05-2011, 06:07 PM | #6 |
thats were i bought mine from. mine had power brakes origanlly.
08-06-2011, 04:26 AM | #7 |
I tried that one, my linkage was too short..Besides if I were to install th booster, I'd then have to install a metering valve.. It was too much to handle so I went with th original mstr from kragens
http://m.oreillyauto.com/img?url=htt...it.jpg&ttl=30d So I got this one instead.. Posted via Mobile Device |
08-07-2011, 12:38 AM | #8 | |
60-66 Nut
Installing a brake booster has nothing to do with installing a 'metering valve' That is something that is needed when you either convert to a dual reservior master and also with disc brakes.
