Old 08-04-2011, 01:58 PM   #1
southwilrise87
no bolts in bed
So here I am driving to fill the tank up. I just got the truck on the road about two months ago but havent been driving it much since Im still doing a little work. Im driving down the road and notice the bed is sliding back and forth. Come to find out the PO never had the bed bolted down. It only slid slightly to the left but now the holes dont match up. Do I need to lift the bed to get it lined back up or is there anyway I can slide it over that wouldnt necessitate a lot of help?
southwilrise87 is offline   Reply With Quote
Old 08-04-2011, 02:02 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: no bolts in bed
there should be a small rubber pad between the bed mount and the frame mount, you will need to lift it, line the bolt holes up and place the pad in correct spot then lower the bed and bolt it down, leave them all loose untill you have it right where you want it, then tighten them up.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-04-2011, 04:00 PM   #3
sinnersahuayo
Re: no bolts in bed
when i bought my truck i had the same deal the last owner did bolt the bed down. i had to stop at lowes and got 4 in long bolt and nut, also some rubber. its was like 10 buck for everything.
sinnersahuayo is offline   Reply With Quote
Old 08-04-2011, 04:12 PM   #4
wildearp
wildearp's Avatar
Re: no bolts in bed
You can clamp a piece of 2" medium or heavy wall square steel tubing or a 4x4 across the bed rails and then lift the bed up with an engine hoist.
I don't think there is more than one bolt currently in my bed.
wildearp is offline   Reply With Quote
Old 08-04-2011, 06:31 PM   #5
Slow Build
Slow Build's Avatar
Re: no bolts in bed
Me too. I drove about 40 miles home with the bed full of parts. About 3 miles before I got home I made a left turn and the whole bed slid over and started rubbing the inside of the passenger side rear tire. I decided to just let it rub and drive home to deal with it. I just ordered the rubber pads, slid the bed to correct place and went under the bed and just lifted it enough to get the pads in before bolting it down.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
