08-04-2011, 03:54 PM | #1 |
Chevy 230 Engine? Numbers?
Hey guys, I have a 66 C10 that I am working on (see build thread in signature), and I want to know if the engine is original and if not, what the exact specs are on it. I know it's a Chevy 230, but where would I pull numbers to determine the date of manufacture, etc?
I would like to order a rebuild kit for it and I would like to make sure I get the right stuff. Any advice on where to get a good kit would be welcome also
66 Chevy C10 Stepside LWB My Build Thread 75 Harley FLH 84 Mercedes 300TD Diesel Wagon |
08-04-2011, 04:37 PM | #2 |
Re: Chevy 230 Engine? Numbers?
Man you do not need to worry about changes that engine has been around for awhile, the data tag by the drivers left leg should tell you what the truck came with, here is a link to checking it to make sure what it is. Kieth
this comes from the FAQ section above: https://skydrive.live.com/?cid=9169a...5CFC6D79%21354 |
08-12-2011, 06:44 PM | #3 |
Thanks Kieth. I'd still like to know what year it is, etc. I suspect that it's not original and am looking for someone with experience with casting numbers.
From what I am reading, it's a tough thing to tell for sure without pulling numbers directly off of the crank stamp.
08-12-2011, 06:50 PM | #4 |
"Where were you in '62?"
Chevy Six Cylinder Casting Numbers:
http://67-72chevytrucks.com/vboard/s...d.php?t=356268 Online engine resources (casting numbers, calculators, etc.) http://67-72chevytrucks.com/vboard/s...d.php?t=382583
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-12-2011 at 08:29 PM. |
08-12-2011, 07:44 PM | #5 |
Thanks 1bad62...
Maybe I should qualify my problem a little more clearly. Below are some pictures of what I believe to be the casting numbers for my engine. Are these the correct numbers that I should be pulling? If so, they are not listed in the resources above. This is where I am confused. 348675 GM 78
08-12-2011, 07:48 PM | #6 |
Here are some additional numbers that I found on the passenger side of the engine block.
CON2 E224
08-12-2011, 07:50 PM | #7 |
Here are some that I found on the intake manifold, I don't know if they're relevant.
343303 GM 37
08-12-2011, 08:06 PM | #8 |
I know this is a lot of pics, but I also found this number near the distributor:
CE4 08904 Also, my VIN is C1546Z149943
66 Chevy C10 Stepside LWB My Build Thread 75 Harley FLH 84 Mercedes 300TD Diesel Wagon Last edited by b2948kevin; 08-12-2011 at 08:16 PM. |
08-12-2011, 08:25 PM | #9 |
Ok.... lets see.
It is not in there like you said. The casting is 348675. Anyhoot I did find this. If it is 348675 it says it's a Buick 1976-75 250. Click below to see. http://www.enginepartswarehouse.com/...ERALMOTORS.PDF And look at this: 1973-1976 250 1973-1979 235 1973-1976 250 http://www.jameshalderman.com/data/misc/a1/1.xls And this: http://67-72chevytrucks.com/vboard/s...d.php?t=395452 This one has got Ole' 1Bad baffled!
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
08-13-2011, 10:24 PM | #10 |
Thank you so much!!!
Seriously, I really appreciate this. It will keep me from buying a 230 rebuild kit and then having to return it for another. This is a really good reference.
