Old 08-04-2011, 06:37 PM   #1
yellow70
yellow70's Avatar
What body bushings ?
Fixing to start replacing my 70 blazer cab floor. What is the best body bushings to use before starting ? Thanks yellow70
yellow70 is offline   Reply With Quote
Old 08-05-2011, 09:25 AM   #2
Burt4x4
Burt4x4's Avatar
Re: What body bushings ?
I used Energy Suspension Black Poly ~ installed back in 1994ish and all is still working great!!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-05-2011, 03:41 PM   #3
69-72
69-72's Avatar
I put the LMC rubber ones in, I believe they are the only aftermarket rubber ones being made. It took about 8 months before they started to look worse then the 40 year old ones I replaced them with.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 08-05-2011, 11:33 PM   #4
jonesky2
jonesky2's Avatar
anybody else have a opinion? i would also like to hear about it.
jonesky2 is offline   Reply With Quote
Old 08-06-2011, 08:50 PM   #5
1971k567cam
1971k567cam's Avatar
I used energy suspension also loved them easy install just rember to put your shims back where they came from.
1971k567cam is offline   Reply With Quote
Old 08-07-2011, 05:27 PM   #6
yellow70
yellow70's Avatar
does energy suspension come with bolts and all?
Old 08-07-2011, 08:39 PM   #7
1971k567cam
Not the set i bought wish they did would be nice to replace at the same time.
Old 08-08-2011, 05:34 PM   #8
yellow70
yellow70's Avatar
who sell the hardware that you need to go with the bushings?
Old 08-08-2011, 08:41 PM   #9
69-72
69-72's Avatar
LMC sells all the bolts Or if you do a search there is a thread on here that lists all of the bolt sizes.
Old 08-09-2011, 10:03 AM   #10
Burt4x4
Burt4x4's Avatar
When I did mine I simply when to the hardwere store and bought carrage bolts with nylon lock nuts and were ever possiable I uped the size of the bolt. Not the fastest way as I had to make a few trips but like I said after that I haven't needed to even touch them in all the years of use
Old 08-25-2011, 03:36 AM   #11
NW_Ryker
I have the bolt sizes saved on my computer somewhere if anybody needs them.
NW_Ryker is offline   Reply With Quote
Old 08-25-2011, 10:07 AM   #12
BOHICA
BOHICA's Avatar
I will here soon, if you don't mind.
BOHICA is offline   Reply With Quote
Old 08-25-2011, 11:44 AM   #13
jonesky2
jonesky2's Avatar
just got my poly bushings. is there torque specs? also im going to get new bolts, do they need to be grade 8? and whats the best way to install them one corner at a time?
Old 08-25-2011, 11:24 PM   #14
NW_Ryker
A long time ago there was a guy named Steve Chin who knew a ton about blazers. Here is the list he compiled. It has been repeated here before so I'm pretty sure he would be o.k. with it.
Here are the bolts, sizes and lengths starting from the front to the rear, (stock lengths).
Radiator support: 7/16"-14 x 3 3/8" long, (2) carriage bolt
Body mount #1: 9/16"-12 x 6" long, (2) hex head
Body mount #2: 3/8" -16 x 10" long, (2) carriage bolt
Body mount #3: 3/8" -16 x 5 1/2" long, (2) carriage bolt
Body mount #4: 3/8" -16 x 4 1/2" long, (2) carriage bolt
Body mount #5: 3/8" -16 x 5 1/2" long, (2) carriage bolt
When the bolts were installed Steve used 3M Strip caulk under the heads to kep water out of the cabin.
