I might have to get into the 21st century one of these days
I guess I will have to get into the 21st century some day soon. I was reading Sept. Hot rod and they took a stock junkyard 5.3 (they thought) from a truck and put some heads on it and bigger injectors and throttle body. It made 451 hp and 380 ft lbs torque in this slightly modified form. They then put a set of twin turbos on it and played with boost. They ended up getting 1203 hp at 26.8 psi and it stayed together. This was a stock used motor (except for the heads). They did like 60 dyno pulls. In the end, they found out it was actually a 4.8. Those LS engines are unbelievable! I just need to wait until they make a plug and play Computer and harness that connects to our gauges ( and is cheap) so an old fart like me could handle the swap.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Re: I might have to get into the 21st century one of these days
Wow I saw the article you are speaking of but never saw where they said it was a 4.8
For sure the new engines make a ton of power, especially considering their size. All the big 3 are making some crazy stuff, and I for one am glad to see it. Want a reliable, easy to drive 400+hp toy? One trip to any local Gm/Ford/Dodge dealership with some bucks and away you go.
"You can take the man out of PA, but you can't take PA out of the man" |
I am a Referee of life.
IIRC it also had a gigged cyl. in it.It was an interesting article and makes me want a late model powered street cruiser.But alas,I'm with rsavage,it's gotta be plug and play for me too.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Champagne Taste on Beer Budget
Yeah I too am hoping 'they' will come out with a simple plug 'n play wiring harness for these LS engines.
Would love to put a LQ9 6.0 in my 4x4 one of these years! ![]()
Coming Soon: Project 1970 Country Truck |
