Old 08-04-2011, 10:27 PM   #1
BMERDOC
BMERDOC's Avatar
Inliner Valve Cover Question
Ok, Somebody straighten me out. I've gotta pull the valve cover to check the valvetrain on my 250. I looked for a gasket online and all the covers have three bolts on one side and four on the other. Mine has five on the passenger side and six on the driver side. What gives? Oh yeah, it has the integral head. I thought it came from a '77 Nova.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-04-2011, 10:30 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Inliner Valve Cover Question
PS. I found one that matches the bolt holes but the gasket looks a little screwy.
Nick Carter
Old 08-05-2011, 01:50 AM   #3
Clutch442
Clutch442's Avatar
I don't have a good answer for you, but I can bump you back up top.
Clutch442 is offline   Reply With Quote
Old 08-05-2011, 10:03 AM   #4
ed2552
ed2552's Avatar
Get the casting numbers from your block and run them, double check what you have.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 08-05-2011, 02:48 PM   #5
Shaky
Six in a row makes it go...
Shaky's Avatar
Langdon's makes a valve cover adapter so you can run the older valve cover on a 194/215/230/250/292. Did someone put one on your head? This is all I could think of.
http://stoveboltengineco.com/index.p...roduct=1409135
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 08-05-2011, 10:49 PM   #6
68 IRON
68 IRON's Avatar
I searched at RockAuto and thats what it calls out.
68 IRON is offline   Reply With Quote
Old 08-05-2011, 11:15 PM   #7
BMERDOC
BMERDOC's Avatar
The pictured v/c gasket jives its just that extra bit that doesn't make sense. I'm gonna get a gasket and do some trimmin if it doesnt fit. Mine doesn't have that. Mine is either a 77 or 78. I saw something that said 78 was a one year only deal but I'm not sure what the diff is.
Nick Carter
Old 08-06-2011, 05:18 AM   #8
Shaky
Shaky's Avatar
Huh - I didn't know they changed the valve covers on later years. You learn something new every day...
Old 08-06-2011, 11:13 AM   #9
BMERDOC
BMERDOC's Avatar
Just pulled the v/c and found that the #2 intake rocker stud has backed out. Gotta find out why. If nothing shows up I'll just ram it down in there and pin it.
Nick Carter
