Old 08-04-2011, 10:29 PM   #1
65GMCFirstride
65GMCFirstride's Avatar
Door Seal
I installed new door seals. Were easy to install, but I think it is going to be difficult to close the door. I was going to install the latch and give it a good slam!
Is it normal that the doors are difficult to close after a new rubber seal is installed?
Any tricks to the installation?
65GMCFirstride is offline   Reply With Quote
Old 08-04-2011, 10:47 PM   #2
mater63
mater63's Avatar
Re: Door Seal
good luck getting your doors to close right I went through 3 sets before i got my gaskets to work i think the last set came from Steel Seal it seems like the after market seales are too thick i have to leave the floor vents open to let the air out because the seals are so tight
mater63 is offline   Reply With Quote
Old 08-04-2011, 10:48 PM   #3
blackedoutharley
Re: Door Seal
Isn't that the point of installing new seals? So that they....... "seal"?
Keep the doors closed and they should conform somewhat.
blackedoutharley is offline   Reply With Quote
